Bit Socket Replacement Bits
_brian_
Wisconsin, USA
This question relates to all bit sockets, hex, torx, etc and is not brand dependent... where do you get replacement bits for bit sockets? Do you just use any bit from the hardware store, or are there a certain style you should use? Obviously there will be quality differences, but I am referring to the style/design of the bit.
I have bit sockets from Craftsman, Gearwrench, Genius, OEMTools and ATD mostly. Some of them have a retaining screw, but most are the press in, where the broken bit would be punched or pulled out and a new one hammered in. I mentioned the styles I have only to give perspective on the question.
rust in the eye
Chicagoland
Tool truck sells them. Most others would probably warranty the whole "socket" or leave you twisting in the wind.
I've cut off hex keys in the past when in a bind.
If yours are 5/16" drive hex Harbor Freight sells an impact driver that contains various bits that size. I'm sure quality is so-so but......
_brian_
Wisconsin, USA
Yes, the warranty will cover the replacement of the whole socket. However, if I need the tool, just fixing it can be easier/faster than waiting for a replacement. I am more interested if the bit needs to be of a certain style/design. You know, some bits are a hex shank to the end, others have a nub of sorts where the groove is used for retention, etc. If it is a matter of just using any bit with the proper size shank, then no problems. I have never pulled a bit out before as I have yet to break one, so I do not know what the bit inside of them actually looks like. My query here is proactive vs reactive.
NoahG
Detroit, MI
I just drive them out and replace with whatever I have on hand, it’s often an upgrade over OEM.
And most store brands just use 1/4” shank hex bits in their sets anyway.
