Black & Decker RP200 Type 1 Collett missing
RedToolBox
Northwest Louisiana
I have a Black & Decker RP200 Type 1 router. Evidently it's a older tool that many parts are not manufactured or supported.
I did a search for the missing 1/4" Collett. I have a nut. I did a online search for it with or without the Nut. On a supplier website it says the part is not available, Out of Stock or discontinued. Evidently this tool is very old.. I purchased it from a Pawn Shop.
It may be possible for a Collett fitting a Dewalt Router could be similar enough to fit. I'm not sure it would. Does anyone know how to get around the discontinued situation for parts on this tool?
Lightning rod
Toronto , Ontario
Seems like a simple part
Are you comfortable to make one by hand
start with some tubing and file away?
I guess the other way is to go to a hardware store and see what type of collet
is on the shelf. See what might work/modify
R
RedToolBox
Northwest Louisiana
I'm not sure about this 🤔 Hardware Stores these days Cary a limited supply of specific parts for older model tools.
Tubing seems a bit softer than materials Collett fittings are made of. I'm still searching for it online but I may have to modify one made for a different model.
Thanks for the reply 👍
R
RedToolBox
Northwest Louisiana
I ordered the parts in the screen shot that I found on eBay. Later I'll see what fits. I used Calipers and it looks like the 6mm one may fit. Since there's 6 in the package I'll have options. I'll let you know if it works out!
Tool Pants
San Jose CA
I hope there is a big reward. Looks like the original part number was 133484-00 replace by 90593213P for model RP200 and also 76XX series routers. I suspect the number change is from when Stanley Black & Decker re branded some Black & Decker tools as DeWalt.
Internet search on the older number found 2 places that say they have the collet. Search on the new number and Tool Parts Pro in California says on their website N/A, BUT they have 2 for sale on ebay. Ebay is the cheapest $11.85 with free shipping. I'll try a link. When I searched on the internet for the new part number it always came up N/A. Got lucky with an ebay search.
Do your own investigation as I don't want to be responsible if it is not the collet that you are looking for.
R
RedToolBox
Northwest Louisiana
Thank you for the informative response! I'll check it out and of course I'd never blame you and any negative outcome. I just appreciate you being here to respond to my post! Thanks 😊
R
RedToolBox
Northwest Louisiana
I
Tool Pants,
I ordered the one you linked in eBay and I'm looking forward for it to be delivered.
Thanks again 😃
The Cobbler
I think your important measurement is the OD ,and partially the length, although that can be ground shorter the taper may not be as important as it should self center even if it's not the same.
post up some measurements and we can maybe help you
The Cobbler
R
RedToolBox
Northwest Louisiana
look at model AR1/4
I have already ordered that because the measurements was the 6mm one. I'll try it when it is received.
Thanks
Tool Pants
San Jose CA
2 links to parts places that claim to have the older part number.
I would try Kaufffman first. According to their website it is a husband and wife tool repair and parts business that has obsolete parts. Looks like they only have one. Their phone number is on their website so you can call to make sure that they actually have the part.
Your router only takes 1/4" bits. When I searched for the collet I saw generic 1/2" collets. Such as post #2. So don't rely upon the images.
R
RedToolBox
Northwest Louisiana
I received the correct one 6mm in the mail a while back ordered on eBay. I really received a set with different sizes that had the one I needed. I also received one with a single collet in the package from a different vendor that was the correct one.
I placed it into the shaft and put the Nut on.... problem Solved! Thanks for your help and all members that responded to my post!
