olds70supreme
- Joined
- Mar 7, 2008
- Messages
- 694
Two questions regarding work I am doing on a '68 Cutlass Supreme.
1. Do "blank" grommets exist? I am looking for grommets for existing holes in the firewall, some with wires/cables going through and some that don't. If I had an assortment of rubber grommet blanks I could drill the appropriate sized through-hole in each one to fit the individual needs/sizes of the cable passing through. Does something like this exist? I am trying to keep the openings in the firewall to a minimum.
2. Throttle cable modification - The throttle cable attaches to the accellerator pedal by means of a barrel-looking clamp on the wire itself. I want to move the location of this but am not familiar with wire clamps. What is the original style called, and is it possible to duplicate? If not, what is the most reliable clamp that I could use?
Thanks.
Thanks.
