My suggestion would be to frame the doors with 2x10's to bring the doors out beyond the block.
Are you crazy? you must be smoking something. You don't want to bring the door out from block or wall of the building.
Petebob- I built same style as you, block wall foundation and 2x4's. The block is 8" from the footer up, then it transitions to 6" just below grade. So far this has served two purposes:
1) When the floor is poured, it sits on a 'ledge' around the inside perimeter of the garage, approximately 2".
2) If you use 2x6" sill plate it completely covers the 5.5" wide 6" block.
After your wall is framed and opening for the garage door, you put up a jamb with 2x6 material.
I'll see if i can find some pics on my build. My crappy webhost has been having some issues lately.
8" block to 6" block transition &
2x6" pressure treated sill plate (don't forget sill sealer foam!!)
2x6" jamb - it installs flush with the inside of your 2x4 wall, so it protrudes out about 1 to 1.5" on theoutside.
There's tons of pics on my build, just click the link in my sig. If you need something more specific just ask i got over a thousand pics of my build.
There may be other ways to frame oh doors but this has worked out good for me.
Torque1st - How would you ever install tracks for the garage door if it was installed 2-3" outside of the interior wall as you suggest by using a 2x10?
Got any pics of this type of install?
