Block Wall Dryer Vent
dhaas66
Is there such a thing as a core drill bit to drill a dryer vent in a block wall?
This would make the job so much more easy.
thanks.
David Haas
lilredex
Toronto
Had a guy come over and drill one of those through a poured concrete wall. He drilled a small hole and installed an insert for a bolt, then hung the drill from that and cranked in the drill.....something like a Cole drill. It went through the concrete like drilling butter. Left behind a round concrete core.
Found him through a local paper ad and it only cost $10........but that was 1973.
So, yes there are drills for that, talk to rental place for details.
mobiledynamics
Gotham City
Cement Block or Solid Concrete.
A 4" SDS MAX core bit will run your about 150'ish on average.
To have a guy come out with a a real coring machine, around here, $400-600 to make that 4" hole. YMMV. The coring machines/core bits are a different animal though. Less blowout, eats rebar, you name it.
I just made one with a SDS core bit.....in cement block and brick. It was a fairly clean hole....
mds5951
You can rent a 4" core bit around here for about 50/day.... Assuming you have a sds drill. If not you'll need to rent that too... Or find a friend
JonBoehman
Philpot, Ky
Hammer drill and mason bits. Drill the diameter of the hole the knock it out with a hammer. Clean up the hole with a chisel. I did about 6yrs ago. I think it took me about an hour to do.
kbs2244
I rented a 4 inch drill from Home Depot.
I expected hollow block.
I got filled block.
Four hours for 2 holes instead of one.
I had to come in from both sides after I got far enough in for the lead drill to poke through.
If there is a next time, I am hireing it out.
mobiledynamics
Gotham City
4 Hours seems awfully long.
Just curious. Was it SDS on a thinwall 4" Core bit
Or SDS Max
Was the bit teeth - carbides all on it.
Just curious..
signcrafter
Do you guys just hold onto the SDS while drilling the whole time? Seems like that would get heavy! Any chance of it catching and taking you for a ride?
BlindViper
York, PA
Thats why I recommended a clutched type core drill bit. They are designed for hand use. One the bit is in the wall you aren't holding as much weight.
kbs2244
4 hours was total time.
I was on a step ladder.
The drill is pretty heavy.
And I was 67 at the time.
I took some breaks.
theknurl
SoCal
i called the core drilling guy, "i want it right here"
$206......the wall was poured solid and had rebar too
my dryer duct is about 8 1/2" long.....saves on gas;)
