Andy, I used to be the one adding "character" for the next owner. Feeling a little guilty. I made Masonite sliding doors in the garage of our last home and painted one side. The paint (or something else) caused the doors to bow so they were very difficult to slide. Never fixed them!"When they opened the door wide, they couldn't open the awning window. To fix the problem they moved the window away from the door and the door away from the window until they cleared. Then they patched the siding. I moved the window a little more away from the door and I'll be re-framing the door with less blocking."
Sad when a new owner doesn't care enough to keep the character of an existing building and instead just wants it to look like it's new instead of a classic.
Where will it all end...
I should be able to add some new and different character to the workshop structure. It will never end...
Hi Rian! Thanks for stopping by and you're right. It was cold outside this morning (by South Florida standards). I'm talking 48*F (9*C) and breezy. It warmed up a little but the workshop project is in the shade of the carport and there's a tiny heater in the shed. Instead, I pulled the '87 Corvette out in the sunny driveway and installed that automatic A/C vacuum controller that I rebuilt last yearGreat progressBob.
Always a job or two to do.
The box is located above the accelerator pedal behind the vanity panel. All I have to do is stick my upper body into the space, swivel my head as far as it will go and remove all the stuff in the way. At one point I was bent over backwards and questioned my ability to get out from under the dash. I didn't take a lot of pictures because of the spittle all over the lens. Suffice it to say the job is done and I am going to find out which body parts are hurt, probably later this evening.
Kirk, if I slow down Liane calls the mortician.Dang Bob, you're a one man dynamo. I have 2 hands and can't get as much done as you do.Can you slow down, you're making me look bad.
Drives, I feel like the biggest part of these repair jobs is "moving all the stuff" and trying to move it to a place where it will only need to be moved back. I haven't been real successful but now I buy lots of casters so the multiple moves are easier.Bob: I wasn't going to say anything about the window framing since it's only a shed, but that added board you put in really makes it look right now. nice work.
thanks for the tip on the pony wall (I think that's what they call it) and i built one on the back of our house when we re did that framing 26 years ago. for my kids house's garage which is where the rotted sill is they have a ton of stuff up against the wall so I was wondering if there was a fix without doing a pony wall so we didn't have to move all their stuff.
that said it's probably a fairly easy fix once we start it, but the trick will be the upgrade instead of putting the sill back maybe putting in a cement riser to put the new sill plate on to keep it from rotting again.
keep up the good work and always fun to see what you are doing. i'm still wrapping my head around your come along moving that planter a few feet.![]()
Philip, I think a lot of development houses built in the early 1950s had big markups on anything extra or different. The Cape Cod houses in our development had a base price just over $10,000 and the Ranches like ours were just under $12,000. The fireplace and extra window in the kitchen eat-in area bumped the house to $14,500. The fireplace also made the eat-in area two-feet longer.There is a job listing in cities called the "Urban Forester." That's the person to-whom you submit your requests for tree removals. It's also the person who disapproves your landscape addition because it's "the wrong tree in the wrong place." Actually, you can understand that better when your neighbor to the back plants a bunch of palms directly-underneath the power company service lines. That's what we're facing, and now all those trees are growing into the lines. Eventually the power company will come-in and chop-down the trees, when they cause power outages. So we've got that to anticipate. My wife (the E.E.) tried to talk our neighbors out of it, but they planted these power-interrupters anyway.
I have a friend who is a graduate-degree landscape architect, who works for one of the east-side cities between Miami and Boca Raton. I ask him for advice from time to time. He did a landscape design for me to get me through an issue with the local city administration. Shut them right-up. "Comply with code!" works both ways!
When I see your progress in fixing things, it motivates me to do something else around here. You're in St Johns, north of Lansing, I believe that's home to Saylor-Beall. They make a good product (air compressors).
Ain't dat 'de-truth! Again, when Bob works, I feel-guilty about not having-accomplished more, and go do something-else.
The Hudson River Valley is a very-scenic place to be. I bet you couldn't believe your good fortune when you got your home there. I'm surprised your house was one of a few having a chimney. I would expect more homes would have fireplaces. I had a friend in Highland Falls (NYS 7W) across from Poughkeepsie, and the property went right-down to the river. I visited him in the fall and the spring, and the fall colors were a real treat, it looked just-like a Thomas Cole or Asher Durand Hudson River School of painting, which after-all was the source of inspiration for these artists, and Washington Irving's fantasies, The Legend of Sleepy Hollow and Rip Van Winkle.
My parents built a new 2-story home just before WW II up-by Lake Ontario, in western NYS just-south of the Erie Canal. In the winter we had a view of the freighters on the lake. It had a fireplace, and was big-enough that it held 5 siblings. It cost $4,000. Their six-bedroom 2-story custom home they built (with built-in central AC!) in 1957 was a step-up, as it had a large 2-car garage, an open floorplan, and vaulted ceilings in tongue-and-groove hemlock. That one was $17,000.
Your GTO was a lot of fun to drive, I bet. I had a '67 convertible for a bit, but after a brief ownership, when I was offered three times what I paid for it, "bye-bye!" Recently, I was cleaning-out a shed to demo it and I found a set of headlight bezels for it. I also turned-up a spare set of Hurst-Hatch t-tops for a 1977 Pontiac Trans-Am I used-to own, still in their OEM factory GM naugahyde carrying bag. It was a gold-pinstriped "Smokey and the Bandit" 6.6 litre Pontiac engined model, I bought from the original owner, it was $10K before the "limited availability" dealer Ben Dover surcharge.
A lot of the west bank of the Hudson River between Newburgh and Kingston is undeveloped so it is a wonderful place to go boating. Our last cruise in the fall was always at the height of the foliage changing color. All along the steep banks of the river on the western side there are streams and waterfalls that can only be seen from the water. It was a really special time in our lives. The eastern shore has the New York Central/Penn Central/Conrail railroad running along the shore. Makes for a scenic commute to work in Manhattan for a lot of people.
If you bought a house before 1934 and the FHA, you usually had to come up with a 30-to-50% down payment and repay the loan in 10 years or less. Your parents probably had 10-to-20% to put down and stretched the mortgage to 20 or 30 years. Back then, $100 a week was a rich man's income.
The GTO was a fun car and I would have kept it forever if it had air conditioning. It didn't and that was fine in upstate New York but unacceptable in South Florida. I wore a suit to work every day and wool, a black vinyl interior and no air conditioning made for a damp commute.
Your Smokey and the Bandit Trans Am was the last of the muscle cars for a long time, as I recall.
Kirk, with all the free compressors Saylor-Beall must give your friend all the time, that seems kind of selfish. I gave away every single free IBM Personal Computer they gave me. Oh wait, that was none...Thanks for the compliment Driftpin. And yes Saylor-Beall is here in St. Johns, and well as the engine component supplier Mahle (they make pistons and turbos). I have a friend who works for Saylor. I keep asking him for a free sample of a 2-stage compressor, but he always turns me down. Can you believe the nerve?![]()
I've got a nice little job coming up, a tree house repair, the ****** thing is bigger than the first flat I bought.
