Matt_C
So I just received two orange hard handles (the blades in them aren't SO) with a view to removing the blades and keeping the handles (original thought was to remove the black hard handles from my two trim lifter tools and swap them over)
Not having a vice and trying to avoid damaging the handles, I decided to boil them. Heated a pan of water to boiling, then lowered it to simmering, and kept the handles submerged for 3 or 4 mins, making sure not to let the handles touch the bottom of the pan. Grabbed the blade of each with a pair of mole grips, and with an oven glove, simply pulled the handle off the blade. Easy as pie.....
Only problem is, the handles don't seem to like it. Then went from this;
To this;
Very white and chalky. The top handle in the 2nd pic is untouched from coming out the water - the bottom handle has had a WD40 bath. That still didn't remove the white chalky finish. I had to use a scouring pad and scour the surface, then T-Cut and finally clean with WD-40 again. They're both pretty much "chalk" free now, but still look pretty faded compared to how they were before. And the black logos and warnings are all but gone (which is a shame, as these handles don't have model numbers on them, so good for swap overs)
So beware about boiling them. They're not too keen on it!
To this;
