I'm looking for advice on properly bolting down a gun safe.
The safe will be on the second level of the house, on top of carpet, carpet padding, sub floor plywood, and finally floor joists. I know to remove/notch out the carpet area where the bolts will be secured to avoid damaging the carpet when drilling the pilot hole. The best case scenario would be to bolt into the floor joists, but I am not 100% sure all 4 pre-cut from the factory bolt holes will line up to hit them. When it comes to the bolt itself, what should I be looking at? What length?
Please note: bolting to concrete is not an option
Thank you
Thank you
