jhcrowman
Installing a new 200 amp service panel and when tightening the bonding screw on the neutral buss, the screw just spins and won't bite into the panel case. I guess I cranked down on it too much?
If I understand NEC 250.28 I should be able to add a bonding strap in its place, correct? see picture as an example.
I'm assuming I'd have to drill and tap either 8/32 or 10/32 depending on the screw size on the strap to get the correct number of threads in the metal case? Or would a self-tapping machine screw work just as well?
I'd appreciate any suggestions.
thanks!
thanks!
