Bosch 12 volt Impact
makgreens
ooltewah,tn
Curious to see if anyone has one on here because im looking at getting one for work
ive got a 4 volt mastercraft screwdriver that "works" but it just doesnt really get the job done and ive seen some bosch's around the shop and some craftsman one but the craftsmans have no balls behind em
any suggestions for a small impact thats fairly cheap?
X1 Mike
Flagler, Fl
I love the Milwaukee M12 system, I have the impact, right angle drill, and drill driver. I buy them when a deal comes up and have averaged about $60-65 per tool for new or reman tools. Now I have my eye on the regular drill, borescope, and mini-sawzall.
M
makgreens
ooltewah,tn
Will the impact break bolts loose pretty easy?
The bosch has a ton of torque so id be worried about killing something putting it back on
X1 Mike
Flagler, Fl
It will break bolts loose but you have to remember what size it is. If you use it for its intended purpose it works great, if you expect to remove lug nuts you will hate it. I would say from only trying the Bosch out a couple of times that they are equals.
whatsitsname
Depends on what you are working on. Trim bolts and engine pan bolts are fine. Wood bolts and screws are fine. Engine work and brake jobs not so good.
nato
Northeast Ohio
Um, no...it won't "break" anything. I've got the 12v Litheon Max #ps-41. It's a beast, but it won't destroy or break anything when loosening or tightening due to the spring 're-coil' feedback absorbing system it has. It's not like a traditional pneumatic impact mechanism. It'll remove anything up to it's claimed 77 ft/lbs. I checked the max torque rating to verfiy and although the little impact hung on an 18mm castle nut for about 10 or so seconds, it pulled it right off. It used almost half the charge though on a fresh, fully charged battery.
I used it this past week to reomove an upper intake manifold on a Ford 4.6l in an '07 F150, as well as other numerous <13mm fasteners....it worked great. i'm happy w/ the purchase.
It does ahve its' limits though....
M
makgreens
ooltewah,tn
Yeah its mainly for engine covers,oil pans and so on
Don't think I. Freally need 800 inch pds for that haha..might have to look into the m12 series
M
makgreens
ooltewah,tn
I'm also cuous about the makitas
I've been very impressed with my 18v impact and driver so I might just look at those
Aklass
I have both the 10.8 and 12v Bosch 1/4" impacts, I use them mostly for screwing in wood/sheet metal, and stubborn screw on cars. I haven't had a problem with mine at all
Up And Down
Boston, MA
nato,
Any chance that you will upload a YouTube vid showing what this tool can and cannot do and what spots it can get into? Any vids of tools in action are very helpful to everyone.
Thanks
TheGrooveking
An alternate reality in a parallel universe.
The Milwuakee M12 38 impact 2451 has 1,000 in lbs., were as the M12 impact driver has 800 in.lbs. of torque. Also make sure you guys get impact ready/capable drive adapters if you are using impact drivers. I've had Irwin brand 1/4" hex to 3/8" drive adapter that the 1/4" hex section peened over to the point were it would not come out of the check, yet it would slip even when trying to drive in #14 self drilling/self tapping screws.
TheGrooveking
Dallus
Flower Mound, TX
I have the Bosch Litheon 12V impact and I LOVE it! I use it all the time and comes in handy on skidplate bolts. I also use it to take the plastic covers off wheels before hitting it with the big boy impact to take the lug nuts off. I work in a quicklube so anything to make my job easier/faster is a good thing!
Wood County, WV, USA, NA
I don't recommend the minisawzall. I know a HVAC guy who has one and its underpowered and slow.
truckdriver
Miami,OK
I have the 12V Bosch and loved it but retired it in favor of the Milwaukee M12, mostly so I could get the Milwaukee grease gun. I like both of them.
whatsitsname
I do recommend the mini hackzall. It cuts through copper pipes, pcvs, tree branches, nails, and wood without any problem. Its quite fast for its size. Can't expect it to cut through a 2x4 with the same pace and efficiency as a full size sawzall.
Monte
Germany
The Bosch 10,8 (12) Volt mini saw will be available in 2011
Damian
Auburn, Georgia
I've personally never used a 12v impact that impressed me. They're ok for under-dash work or zipping off 8-15mm misc bolts here and there, but they don't have any real power from my experience. My Dewalt battery impact is a real impact with some cojones. Makes a 12v Impact look like a screw driver.
Dallus
Flower Mound, TX
A 12v impact driver isn't going to zip off a crank pulley bolt or 90% of lug nuts I encounter. I have an 18v behemoth for that. But when you need to remove a oil or trans pan with 20+ 10mm bolts, you can get it done in no time. Plus my 18v gun weighs 3 or 4 times what my 12v does. I don't want to hold that up overhead whilst zipping off 20 bolts on a pan.
You just have to have realistic expectations of the tool.
M
makgreens
ooltewah,tn
CLPK27-120
and i paid 179.99
hopefully it was worth it
seeing that just the impact was 139 so for 40 bucks more i got the drill/driver too
IndyGarage
Indy
I've got both the Bosch 12v driver and impact and the equivalent Milwaukees. I also have the Milwaukee Hacksall.
I've had the Milwaukees for a couple years, but a few months ago Bosch came out with their newer, faster, more powerful models, and I saw a set on Black Friday with a ridiculously low price, so I bought them to use at my workshop.
The new Bosch units are way more powerful, and much faster running, but after using them for a couple months - not extensively, but enough to get a feel - I still like the Milwaukees better.
For some reason the Bosch units just don't seem to be made as well. First, there is a delay when you pull the trigger. It's slight, but noticeable. Second, the forward/reverse switch seems to have a lot of play in it - often I have to mess with it to get it to work right. Third, the quicklock chuck on the Bosch's aren't as good, and this may be a problem with mine only - but a couple times when I left the driver out in the cold garage, it wouldn't work at all. This happened this weekend. I picked up the milwaukee and it worked fine. The Bosch driver doesn't have the battery gauge - which curiously is included on the Impact and is on all the Milwaukee units.
Also, it may just be me, but it seems the Milwaukees have better battery life - of course that may be due to the fact that the Bosch's do have more power and speed.
I'm looking forward to the next gen Milwaukees, that are surely going to be released this year.
As far as the hacksall - I have a mixed review. It does accomplish light duty cutting way faster than you can do it by hand, and it is way more compact than a sawsall. I've used it to cut copper and PVC tubing and for a multitude of other small jobs. It's not very powerful though. It vibrates like crazy and the battery life is pretty bad. On my last use, mine developed the habit of shutting off after about 5-10 seconds of cutting - I recharged the battery and it stopped, then later it started doing it again - must be an electronics problem. I was really looking forward to it when I bought it, but I've been a bit disappointed.
M
makgreens
ooltewah,tn
Well, got a chance to use the impact and drill at work today and I'm very glad I bought em
Besides the slight delay they work very well, hopefully ill get to test em more this week
whatsitsname
I would have gotten the Bosch. It has a lot more powerful the Milwaukee, Makita, and Hitachi. I only returned mine because they don't have the extensive line of 12v tools as Milwaukee does. They certainly have a better tool line than the other brand's 12v series.
