Bosch switch reassembly
seagull369
Trying to re-assemble this switch, which came out of a Bosch R/O sander, and can't figure out where the clip circled in white goes. Any guesses?
KnurledNut
n/a
See if it fits in the farthest bottom/right rectangular hole.
There are two other similar tabs in the holes beside it.
whateg01
doo dah, kansas, usa
There's nothing in the mating part for it to match up to in that joke so I doubt it. I take pictures as I'm disassembling things with parts. Still miss the item I need to locate though. the other rectangular holes have contacts in them for the wire to push lock into. That extra part is clearly not shaped the same.
seagull369
Like "whateg" mentioned, the ones that look similar are actually different and are the stab-in connections for the wires.
I usually do that, but the pieces inside all Jack-in-the-boxed out on me as I pried the switch open.
whateg01
Can't tell, but it almost looks like something used to live at the end of the spring. Maybe inside the spring to keep it from collapsing and maybe act as a stop.
seagull369
KnurledNut had it right. It goes where I added the yellow box in the pic- jaws facing out. It keeps the two halves of the housing locked together on that corner.
Thanks for all the help!
