Bostitch coil nailer repair
Zebu Fellenz
Phelps, NY
Hey Everyone,
I'm building a lean to on an existing pole barn right now and borrowed a Bostitch coil nailer from a friend to make the project move a little faster.
The nailer hasn't been used in a few years and my friend mentioned that it had been jamming last time he used it.
I loaded it with new nails and went to use it, sure enough it jams, more specifically the firing pin will not retract after shooting a nail. There is a (large) air leak around the trigger valve. Am I looking at new o-rings on the trigger valve, a new valve, or possibly something more?
I believe the nailer is a N80CB-1
I want to get this fixed quick so I can get back to work and of course return it better than I got it!
-Cheers,
Erik
Snap_cap
The city of the broken bell.
When was the last time it was oiled?
Did you add air gun oil before you connected it to the hose to use it?
IME (N-80S), in normal use, there is some air leakage at the trigger but not enough to interfere with the operation ability of the gun.
Check also to ensure that there isn't a piece of nail coil wire fragment jammed into the drive anvil mechanism. I've seen this happen frequently on Bostitch coil roofing nail guns (N-12 series) just from rapid pace use (not abuse). If a piece got in there, it may be causing the failure you describe.
slyonedoofy
Vantucky,WA
Hey Everyone,
-Cheers,
Erik
Last time I bought parts for mine was on Ebay. Not fast but at least I could get them.
Mine was leaking air and it was the big seal under the cover on the top that broke.
Something to look for.
The Cobbler
probably needs a trigger kit. mine did the same & I tried to replace the orings, but I recall there was an odd shaped washer inside... that only came with the kit. about $25 if I recall
Zrexxer
Pflugerville, TX
I've found Bostitch nailers to be notorious for trigger seal failure. IIRC it's a ridiculously expensive kit with trigger valve with like two o-rings and a tube of silicone grease in it.
