Fluxion
Ok, this is my first post here. I have been lurking for awhile and have decided it was time to start posting and I'm pretty excited about my latest acquisition!
My Dad and I bought two air compressors at an auction last weekend and finally got them home today. I went to buy one (the blue one in the pics below) but the other went so cheap Dad bought the other. We cleaned them up a little after I took the pics and plan to temporarily hook them up and make sure they run tomorrow. I also plan on moving mine into my shop this weekend and start the prep work for building a small lean-to shed just for this and my dryer. I kind of hate to even mention the price but I paid $120 for mine and Dad paid $160 for his. The only other bidder on either one was a scrapper. Now for some pics and a few questions at the end.
The blue one definitely has a Quincy 325 pump but the number to the right of the model is 102 so is the ROC 10? This one does have the inter-cooler and the oil filter. Also this one has a 3hp 3 phase motor and of course I will have to replace it with a single phase motor. I was wanting to install a larger HP motor, 7.5HP or maybe 5HP. I read that with the 7.5HP I can run the pump up to 900 RPM, Is this correct? I don't know what tank pressure this was run at but the working pressure is labeled as 200 psi. Aside from possibly needing a new safety valve and adjusting the pressure switch, what other adjustments would be needed?
The gold colored Binks of my Dads looks to have a Quincy 325 pump although a little different configuration. Can anybody help make a positive identification? I can take more pics if needed. This one is equipped with a 5HP 3 phase motor and Dad has 3phase in his shop, so he wants use it. There are two unloaders on the head and it doesn't have a pressure switch installed. Could this be set up to run the motor continuous? If so, what would be involved in switching over to run with a pressure switch? The safety valve on this one is rated at 125 psi and we would like to run the compressor at higher pressure. The tank is rated at a working pressure of 200psi so after replacing the safety valve, what adjustments would be required?
Can anybody point me to any more information on these? I would like to know all I can about these compressors and I am sure I will have more questions later.
