Bowling ball welding table
willy3486
Middle Tennessee
I have a question on the bowling ball welding tables I have seen made. These are the ones that has two rotors holding a bowling ball and they grip it when a jack is raised. I am wondering on this instead of a hydraulic jack could one of the newer scissor type jacks that you wind up on newer cars be used? Would it grip it enough? Is there a reason not to use a wind up jack? I am the gathering up stage of making one and hope to weld it up in a few weeks.
drmarkr
Tucson
Googled it. The hydraulic model is fooking badazz. How would you work the scissor with your foot though?!?? I see bottle jacks as cheap as $20 on Amazon....
Murby
I've been welding for 40 years and the bowling ball welding table seems kind of pointless.. at least to me..
Something far more useful would be a motorized rotator.. something that rotates a pipe or an object while your grinding or welding so you can go full circle without stopping.
W
willy3486
Middle Tennessee
For those who are not familiar here is one. I plan to do a different type top.
bowling ball table
The hydraulic model if fooking badazz. How would you work the scissor with your foot though?!??
Instead of using my foot I was wondering if I could just turn the handle with my hand. One issue might be that I would have to bend down more than I want. I have some of these. But after thinking about it I may go ahead and use a hydraulic jack.
W
willy3486
Middle Tennessee
I plan on using it for other things than just welding. I will make a post for it when I make it showing how I plan to do it.
DaveAndStuff
Bangkok
We had a few rotators to weld flanges on rounds and they were pretty handy once you got them dialed in, and rotate them 90 degrees. They have really gotten cheap too.
I think the bowling ball thing would be more useful if it tipped 90 deg,, but it is still pretty small.
Beerhippie
Far NE Oregon
You'd have to scale this up a bit
but it will go to 90 degrees.
I suspect the original maker of the BB table got the idea from a photographic tripod ball head. The one in the video locks like a standard Arca-Swiss.
DaveAndStuff
Bangkok
I suspect the original maker of the BB table got the idea from a photographic ball head. The one in the video locks like a standard Arca-Swiss.
The last shop worked we had four powered rotator that rotated 90 degrees that would take a 48" round, and a vertical rotator that would take at least a 12 foot.
whateg01
doo dah, kansas, usa
You'd probably have to have a custom ring cut out, but if the upper has an ID big enough (grips past the +/- 45 Mark but above the equator) it could be easily made to go past 90.
That requires somebody to make a spherical bushing to go around the middle of the ball. That's what makes op so attractive is that most people can find an old brake rotor or 2 laying around.
W
willy3486
Middle Tennessee
I can see that being very useful as a mount for a bench vise. Kind of a giant PowrArm.
Cha ching! This is what I am looking at doing. Install a vice so I can use it as a vice, make a metal to use as a welding table and also be able to use my tabletop B&D workmate on it. Keep in mind I do little as far as cars but I do woodworking, electronics and some welding. I want it versatile as it can be.
Muttly
Mid-MI
I'd use a bottle jack like this before I'd use a scissor jack:
You could mount it upside down so the adjustment was closer to the table and adapt it to accept a wheel handle or socket to use a ratchet to adjust.
The one pictured is from a 2000-2017 f250 or f350, so they are easy to find in junk yards and heavy duty.
aka Larry
Eastern, NC
bowling ball table
Neat. Kind of like a giant RAM mount for a phone.
bwringer
Indianapolis
bowling ball table
Thanks for clarifying WTF we're talking about.
I bet the bowling ball would get pretty badly scarred in 6 months.
Same, although chamfering the inside corner of the rotor would help a lot; you'd need to chuck it in a lathe to do a decent job, methinks. Maybe that's already part of this build and we just can't see it.
Also, I'd add a strong spring to the system somewhere; even a small hydraulic jack would easily supply enough force to damage the urethane, but a spring would give margin for error. Some sort of spring-loaded over center mechanism would be workable, but overall it's easier and cheaper if you're sticking this together in the garage to just use a cheap hydraulic jack that's probably already lying around.
Some sort of shielding to keep weld spatter off the plastic would be nice, too.
Some way to create "presets" at specific angles would be neato. I can envision a system of dimples in the ball and spring-loaded ball bearing detents in the clamping system. That would raise the level of complexity a fair bit.
And as mentioned earlier, a geared stepper motor under the platform would make this a very handy rotator for many kinds of welds.
