Bowling ball welding table
willy3486
Middle Tennessee
I have a question on the bowling ball welding tables I have seen made. These are the ones that has two rotors holding a bowling ball and they grip it when a jack is raised. I am wondering on this instead of a hydraulic jack could one of the newer scissor type jacks that you wind up on newer cars be used? Would it grip it enough? Is there a reason not to use a wind up jack? I am the gathering up stage of making one and hope to weld it up in a few weeks.
LXCam
I saw the title, read the post and still was like WTF? You talk’n bout Willis
So I looked. Holly heck, that’s badass. 👍
drmarkr
Tucson
Googled it. The hydraulic model is fooking badazz. How would you work the scissor with your foot though?!?? I see bottle jacks as cheap as $20 on Amazon....
Murby
I've been welding for 40 years and the bowling ball welding table seems kind of pointless.. at least to me..
Something far more useful would be a motorized rotator.. something that rotates a pipe or an object while your grinding or welding so you can go full circle without stopping.
W
willy3486
Middle Tennessee
For those who are not familiar here is one. I plan to do a different type top.
bowling ball table
The hydraulic model if fooking badazz. How would you work the scissor with your foot though?!??
Instead of using my foot I was wondering if I could just turn the handle with my hand. One issue might be that I would have to bend down more than I want. I have some of these. But after thinking about it I may go ahead and use a hydraulic jack.
W
willy3486
Middle Tennessee
I plan on using it for other things than just welding. I will make a post for it when I make it showing how I plan to do it.
DaveAndStuff
Bangkok
We had a few rotators to weld flanges on rounds and they were pretty handy once you got them dialed in, and rotate them 90 degrees. They have really gotten cheap too.
I think the bowling ball thing would be more useful if it tipped 90 deg,, but it is still pretty small.
Beerhippie
Far NE Oregon
You'd have to scale this up a bit
but it will go to 90 degrees.
I suspect the original maker of the BB table got the idea from a photographic tripod ball head. The one in the video locks like a standard Arca-Swiss.
DaveAndStuff
Bangkok
I suspect the original maker of the BB table got the idea from a photographic ball head. The one in the video locks like a standard Arca-Swiss.
The last shop worked we had four powered rotator that rotated 90 degrees that would take a 48" round, and a vertical rotator that would take at least a 12 foot.
whateg01
doo dah, kansas, usa
You'd probably have to have a custom ring cut out, but if the upper has an ID big enough (grips past the +/- 45 Mark but above the equator) it could be easily made to go past 90.
That requires somebody to make a spherical bushing to go around the middle of the ball. That's what makes op so attractive is that most people can find an old brake rotor or 2 laying around.
W
willy3486
Middle Tennessee
I can see that being very useful as a mount for a bench vise. Kind of a giant PowrArm.
Cha ching! This is what I am looking at doing. Install a vice so I can use it as a vice, make a metal to use as a welding table and also be able to use my tabletop B&D workmate on it. Keep in mind I do little as far as cars but I do woodworking, electronics and some welding. I want it versatile as it can be.
