Innovate1
Wiring up my detached garage and putting the wiring in the walls. But want to make it easier to add stuff later. Running a conduit from the panel to the attic for that. Also running conduit to a box on the other side of the room so I can pull wire for whatever and using a fairly big box. Any suggestions on what box to use?
Also thinking I will run a conduit out the top of the panel to a box near the ceiling that sticks out of the wall so I can attach conduit later and run where ever. Thinking a deep enough box to connect to the conduit in the wall and also on the surface something like this:
https://www.menards.com/main/electrical/electrical-boxes-covers/electrical-boxes/carlon-reg-pvc-enclosure-box/e987rr/p-1444444973855-c-6425.htm
Or should I just use a large metal box that is flush now and add an expansion ring later if needed?
