beavergarg
- Joined
- Feb 14, 2013
- Messages
- 3
So I've been putting together my lighting upgrade for my 25x25 garage. It has unpainted drywall and open truss ceilings. The bottom of the rafters is 8.5' high.
I've opted to go with 10 150w equivalent CFLs that are screwed in to 10 of these porcelain fixtures. I know I might catch flack for using CFL in a lower ceiling, but I had ribbons taped showing where the lights would be and decided I'm fine with it.
So my question is on the boxes and fixtures design I should use. I already bought 10 of these, even though I should asked here first.
http://www.1000bulbs.com/product/62047/SOCK-D98.html
I was intending to mount these directly to the bottom of the trusses, hence why I got smaller ones.
Question: Do I need to pigtail off my main wire run, or can I use the screws as a connection point to continue the lights? If I should pigtail all of these, I need a box mounted. Can I screw these sockets to the box or should I still screw them directly to the rafters? Boxes have 1 open side that gets covered by the fixture, faceplate, etc. These sockets are too small to cover any box. As you see my problem gets bigger the more I look at these sockets.
I understand the wiring part and I'm having an electrician friend do all the work from the switch to the panel. I'm just curious if I'm bending too much on my light mounting and wiring design.
