Brake Pad Spreader?
dwm
Southeast Michigan
If you have a pad between the rotor and the screw driver then what is between the piston and the screw driver ? Gotta be careful, you might mar the piston.....
True, but I can see Simplespeed's point of view for many OEM brakes. When I replaced the brakes on my BMW M roadster at 26,000 miles, the piston surfaces were pretty much trashed. Very rough, corroded. If I hadn't been putting Wilwoods in, I'd have bought a rebuild kit at that point. Brake dust is nasty stuff, especially on the German cars (thanks to TUV requirements).
But you're right when it comes to decent aftermarket brakes. The stainless pistons in my Wilwoods are not dirt cheap and aren't much fun to replace, and have a much less beefier lip and tighter tolerances than the OEM pistons.
38D
Boston
I have never used a tool at all. Just use your hands to compress the pad a bit, then rotate the old pad 90 degrees to push the piston back in. Also works great at the track 'cause you need no special tools that are invariably back at home.
Simplespeed
On a single or dual piston caliper where the pistons are on the "inside" or closer to the vehicle you would stick your screwdriver in between the outside of the pad and the caliper. You may have to pry on the pad a bit until you get enough gap to get on the other side of the pad but there are no pistons on that side of the caliper. Your basically forcing the outer pad, rotor, and inner pad against the caliper pistons. Same thing with a 4 piston caliper if you do one side at a time. I know some toyotas will let you do that. If they have to be compressed at the same time then you'll have to put the screwdriver between the pad and rotor on each side, cross the screwdrivers and pull apart and push together like your opening and closing a pair of scissors. I have never damaged a rotor this way but i also machine them almost every time. Also, the bleeder should be cracked anyway making the amount of pressure required to compress the pistons very low. Either way, there is nothing wrong with using the right tools.
willysrule
Herminie, PA
I have these two, always work great...I have a few 1/4" thick plates that are cut in the shape of brake pads too if I need to combine that with one of these tools...
Piston Compressor Tool
Lisle Dual Piston
rodi_2152_17427623
00S4Boy
Not so fast, Batman. I'm runing 6 piston forged non-floating calipers on one car. Each side has 3 progressive sized pistons and one pad. Your solution flat doesn't work. Period.
I have yet to try it on a 6 piston, but it works for 4 piston fixed calipers running 1 pad per 2 pistons.
ponchopower
won't work on the 6 pots. In particular, I can assure you in won't work on Wilwood Superlite 6R 6 pots. And you SURE don't want to be prying against that powdercoated billet aluminum OR cocking the pistons in those. A single caliper replacement will cost more than all brake components combined on many other cars.
Rusty67
LA, CA
How did you manage to turn that LITTLE t-handle to compress the piston?? You must be one big fella ...
I'm 5'10" 160lbs and I've used that thing on several different calipers without opening the bleeder valve. I think if you can't do it there is likely something wrong with the brake system or maybe a 1-way check valve in the ABS unit. If you have ABS you should open the bleeder valve anyways....
Rusty67
LA, CA
It depends on what you mean by best. Getting the job done without damaging the pistons/calipers is obviously on the list but do you care about how fast you get it done ?
K5blazer83
Maryland
When I do disc brakes I use either my:
Snap-On GA395
Matco DBPS260
OR for the stubborn pistons:
20" BIG MAC CHANNELLOCKS
and for rear discs:
Matco DB25
biowrench
Anyone know where this might still be available? These guys aren't shipping to los angeles afaik.https://mrmarks.n.my/index.php?ws=showproducts&products_id=2162449Vehicles-Body-Repair-Tools#openproducts
Looks like the right thing for reaching into the 240s calipers.
The mechanic wants $160 per axle for this. "That's new bearings included, right?" "Nope."
Rusty67
LA, CA
At 160 per axle it is most def not including new bearings. You might want to try OTC 7034. That is a cheap/effective tool and works basically the same way as the one you posted. Not quite as sturdy/beefy but I've done cars and motorcycles with it.
sparky 1971
Central Iowa
Flared Base
CA
Looks similar to the Toptul one.
bsaint
Manchester, CT
I wish there was a tool that worked like a clamp that squeezed it when it was still on the car. So since I live in ct, it's always the c clamp to get over the rust lip.
biowrench
Yeah, maybe I'm remembering 1990 or something, when I paid $100 per axle for bearings on the Minima (Datsun 210 Sedan).
Thanks, got the Performance-branded version of the OTC 7034.
bbroxter
Charlotte
Lucid Moments
Gainesville, Ga
Yep, I have done it too. I think what 00S4Boy isn't getting is that you compress one side and put the new pad in on that side, then compress the other side. Or at least that is how I do it. But I admit it would be nice to stick a single tool in there and compress both sides at the same time. Not necessary, but nice.
