Brazing motorcycle crank case.
Gumby919
Las Vegas, Nevada
I picked up a blown motor with a small chunk missing from one of the case halves. Is it possible to braze this back shut and then machine it flat? Other ideas are welcome.:thumbup:
G
Gumby919
Las Vegas, Nevada
It's aluminum and off a kx250 dirt bike I can get access to a tig but not for a couple weeks and I need it sooner then that. I figured that was the best route but a buddy bought up brazing so I figured I would ask. Thanks for the replys
yhprum
Brisbane Australia
Those aluminum brazing rods will cause corrosion in the joint. JB weld may be adequate for this repair with little chance of actually making it worse.
rharman
SoCal
TIG would be a piece of cake. In a pinch, I'd probably chance the JB Weld.
countryroad82
Kentucky
I've used that JB Weld stuff that you knead together to repair similar parts before. Prep is key like anything else. Or like others have said, TIG it.
Greeny
Shreveport, LA
It's hard to get a good idea of the damage from the pic. I've used JB weld and aluminum can material to patch some pretty good holes in cases caused by a broken chain. Good prep and it can work fine.
