breaker lock ?
The Cobbler
a place that I used to work at had many locks on the breakers so that the breakers could not be shut off accidentally or on purpose. they were a metal bracket that were fastened to the breaker handle .they were on things like alarm system power, overhead heaters and so on. they would still trip but you couldn't physically switch off the breaker . I was told these do not exist any more due to safety reasons? .
How can one protect an essential breaker for an alarm system from being accidentally turned off?
thanks
Chumly
Alpine, CA
Lockout/tag out locks, just turned over so that they're locked on instead of off.
Residential Electricians should chime in here. Does the breaker lever need to be free to actually trip? Ripping a square-D one apart has it appear the lever doesn't have to move to physically trip and the lever feel/movement seems like a visual feature
...I don't wanna burn someone's garage down.
Weird thinking breaker panels can be locked isn't it? I'd want quick access to the cut off and not go find a key if a Charlie fire starts. I've had two Zinzco breaker fires so I'm pretty happy I could just quickly open the panel and kill the mains. I'd dump the idea of locking an entire panel just to keep something on. Even the lockout things I'm thinking of can get yanked off if you really needed to; They're just speed bumps.
a place that I used to work at had many locks on the breakers so that the breakers could not be shut off accidentally or on purpose. they were a metal bracket that were fastened to the breaker handle .they were on things like alarm system power, overhead heaters and so on. they would still trip but you couldn't physically switch off the breaker. I was told these do not exist any more due to safety reasons?
thanks
They actually do still exist and are sold, albeit maybe not the ones listed for your panel. I see them on new buildings specifically for the fire alarm system breakers.
FYI, the reasoning they dont exist because of safety is most likely bogus. A breaker can and does still trip regardless of the handle being locked in the closed (on) position...
rlitman
Long Island
Breaker handles do not need to move to trip internally. Note how any breaker can be flipped from the tripped position to on, yet does not turn on unless you flip it off first.
The Master 493B should fit on top of breakers like that. I have those, and 491B for big ones that don't have their own lock-out levers.
But be aware that Federal Pioneer is the same construction as Federal Pacific and Zinsco, so safety? Perhaps not.
T
The Cobbler
I was told the issue was with US federal panels, not CSA rated ( Canadian) panels when I asked about upgrading my home panel after reading that on here
thanks for the tips
thanks for the tips
Federal Pioneer (canadian flavor of infamous Federal Pacific Electric) does not have the same problems
rlitman
Long Island
To clarify, the Master 493B has a plastic lever on top that comes down over a metal body. There's a plastic (it appears to be glass reinforced) ring on the lever, and a metal ring on the body that meet when it is closed. Either one would be easy to snip off.
The lever has a cam that pushes one side of the clamp, while a screw that is accessible when the lever is up adjusts the other side of the clamp.
dscheidt
Garvin sell a nifty little bracket that serves this purpose. It has no provision for locking out, just a set screw that keeps the breaker handle from moving. Put it one way, it keeps them off, turn it around it keeps them on. You need a small screwdriver to back the set screw out, so they're just tamper resistant, not tamper proof. https://www.garvinindustries.com/pa...t/universal-breaker-locks-one-pole/p/UBL1-RED
They also work on standard toggle style wall switches.
Chumly
Alpine, CA
I don't think any hard, full metal lock will make it impossible to activate if you really wanted to de-energize the circuit. However, it should alert anyone to just not randomly turn that one circuit off or on; Lock or not. If you want to deter someone to not turn a circuit off, the LOTO breaker "lock" should do just that. If there's a lock on it, a screwdriver will get it off quicker than finding bolt cutters for a lock placed on it.
Ugh, there's a huge on-going discussion about hanging locks on these things too for too many years with nothing but suggestions in OSHA regs. A Standard MasterLock is too heavy and pulls on the breaker and causes sag and thus far is suggested to use those tiny suitcase locks or just zipties. If it's for work, be careful since it's a LO/TO device, please. We're seeing more of that lately in the states. One guy, same age as me, said there's no lock out where he came from which I highly doubt. It's OSHA.
Chumly
Alpine, CA
Redneck in me says "Paint them red", but the redneck in me also says "I know others like me" >:)
Paint won't physically stop someone, but would stop me or at least make me think twice why my finger is on the switch painted red. Loose fingers bug me so I like contraptions over all like that clasp just keeping other's fingers off of that thing. we're drawn to triggers and we're not always around to slap hands.
ycgoat
S.E. Va
It may be a code violation to lock most breakers on, I could be confusing disconnect switches (I did not research it first) , but the exceptions are typically for life safety like Fire pumps. If people are inadvertently switching the wrong breaker I would resolve with a warning tag, clear labeling, and training or speaking to anyone who may get into the panel. You could also add switches to isolate power at the equipment that is supposed to be turned off, to keep them out of the panel, and it would be easier if the disconnect was at the work location. I will typically put a switch with a lockable cover at my security panels, but that is a 1p 120v low current set up and is done to keep low voltage technicians out of the electrical panels.
nh_yota
Seacoast New Hampshire
Put some red electrical tape over the breaker with DO NO TURN OFF written on it.
If someone ignores it than that is the least of your problems.
grounded-b
Milwaukee, WI
Personal safety is a higher priority than physical property.
If I'm working on a circuit, and the breaker is not configured to be locked off, I will lock the cover to the panel as an alternative
Steve (electrician)
Stice1
Tennessee
I work in the fire alarm industry code requires the alarm panel breaker be locked. Below is what we use. They are universal, like $5, and allow the breaker to trip just not be turned off inadvertently.
infinkc
Came to say the same thing, seen this done before and never once did I want to switch the breakers off. I have done it with that new dymo tape that you can print on, For the breaker in my panel for my fish tank, so someone doesn’t turn it off.
Chumly
Alpine, CA
Every time I think sometime is Idiot Proof, better Idiots are born.
You found me! I did mention even the LOTO locks can be pulled off with a good tug or a screwdiver, red tape isn't going to slow me down. I'm, however, in the mentality that it's NOT a Lock-out/Tag-Out and just a deterrent to "Please don't turn this off without asking" because it's for the smoke detectors, yet ours are found all the time in OFF because, what I'm guessing, is that they're beeping and they want them to die some day and not fix the issue...dunno.
That's a rant in it's own that I think the OP and several here are feeling.
ycgoat
S.E. Va
We have been installing permanent locking devices on our existing panels and new ones are purchased with them. to resolve the typical flimsy lock out devices. I do not lock devices in the on position, and typically other than LOTO the panels and electrical rooms are locked to ensure only qualified people have access.
yyc_ranger_4x4
Calgary, Ab
We use breaker locks on a very common basis...mostly fire alarms and critical circuits. You don't want someone going in and turning stuff off that shouldn't be. Also, Fire Code states that the Fire Alarm breakers have to be identified red in color. Usually we use the breaker locks that are manufacturer specific....however Rack-A-Tiers and a few others make universal ones.
And yes, the breakers will still trip even with the handle locked on. They trip internally, and the handle will show once you pop off the breaker lock. I'm not a big fan of using LOTO devices for locking breakers on, people start to confuse the proper use and their intent....but I have done it to satisfy an inspector until a proper lock can be had.
