Broke my air compressor - need advice
Jon_E
Southwestern Vermont
Not sure this is the right sub-forum to post this, so mods, move it if it needs to go.
I decided to do one last thing yesterday before the snow in New England hit us. My 1940 vintage Kellogg air compressor had been sitting on a pallet in my garage for at least a year and I had built a dolly to make it mobile. It's not being used, I need to do some restoration and rebuilding. Well, I rigged it with some chains to my tractor loader, and I screwed up the rigging and the damn thing spun around and the muffler hit the pallet and broke off.
So I re-rigged it, got it on the dolly and then checked the damage. I thought the muffler itself had broken but it was actually the head casting. The head casting and the muffler each have a female pipe thread and they are connected by a short pipe ******. The head casting lost two or three threads and the ****** broke out of it. Muffler was intact. So I have a broken casting and the piece that broke off.
How do I fix this? The first thing that came to mind was brazing the casting back together, but that requires a level of expertise I don't possess or know anyone who does. I also considered epoxy or JB Weld, but I am leery of using essentially glue to fix a metal casting. It doesn't affect the functionality of the machine, but it would be nice to have it restored to good condition again.
Plastikosmd
Pics would help
Likely involves brazing/weld (nickle rod)/ threading deeper if possible or machining out damage and recut. I have used them all. Also check eBay or fb market for head
LS6 Tommy
Northern NJ
If the rest of the threads are OK, you may be able to get the right size tap and rethread it a little deeper to open up the taper a bit and reuse the existing ******.
Tommy
