Broken bit head in impact driver
schurtjl
Oregon
Head of a bit broke off inside my Makita impact driver, and for the life of me, I can’t get it out. Tried everything I can think of with no luck. Figure it must be bound up pretty good. Too deep in to weld to it. Anybody have a solution you’ve found to work other than sending it in to Makita?
condition001
Strong magnet? Maybe drill a hole in the middle and hit it with a small easy out? If you were to disassemble the pieces could you get it out? I know my dewalt had a part that could be removed (found that out when the detent ball got stuck). Not sure if any of this helps, just brainstorming
Moosefire
Detroit
Can you take the other end that broke off and try super gluing it on?dont use much, just a drop
Sent from my SM-N960U using Tapatalk
Loosening or tightening? Drill w an opposite hand drill? May unwedge it before an easy out is applied, but may need an opposite easy out?
schurtjl
Oregon
Happened while drilling with a large speedbore into wood. Had tried a magnet but that didn’t budge it. I’ll have to try the superglue and/or drilling...
KnurledNut
n/a
You could also remove the retaining ring, sleeve, and retention balls that make up the quick change. And then smack the side of the anvil nose. I seriously think you are wasting time with superglue and might even compound your problem.
schurtjl
Oregon
Success. I disassembled the impact to see if I could pull the hammer assembly apart but it appears non-serviceable, and there wasn’t a way to drive it out from the rear like I hoped. Ended up using a punch and finally broke it loose from being bound up. Came out easy after that.
B_Bimmer
Eastern Iowa
I had one that twisted off inside right where it is thinned down to lock in. and would not come out by any method I found on the internet. Ultimately I decided it wasn't coming out and I had nothing to lose so I disassembled the chuck and drilled it out with a 1/4" cobalt bit. It ended up working great and I did not damage it at all, so I was happy.
schurtjl
Oregon
I had thought the bit was bottomed our already after being inserted which is why I didn’t initially try to drive it in to break it loose. Didn’t realize there was a little room behind it. Sometimes the easiest solution works...
