Broken oiler?
Inabox85
Ontario, Canada
So i bought an inexpensive oiler. I wanted it for homemade penatrating fluid. Half ATF half acetone. But the mixture will not pump out. Is it a faulty oiler? Or is the fluid to runny? The oiler has a flexible line on it. The mixture does leak out of there a bit but it is as tight as it can get.
Should I try a new oiler?
Do you have any suggestions on the best dilivery system for homemade penatrating fluid?
2oolhound
BC Canada
Try unscrewing the lid and placing the bottom of the pump in a small container (like a lid off a 1 quart container) that is filled with 30 wt oil and see if it pumps. It sounds like you just have a crappy oiler although I have never tried pumping anything other than oil through my oilers. A diaphragm type oiler would work but they don't squirt like the pumpers.
PBCampbell
WV
A spoiler....I've found that penetrating fluids like Kroil for instance, will ruin a pump oiler in short order. Something to do with the solvents eating away the zinc the pumps are made of I think. I wouldn't be surprised if Acetone is as damaging.
mjoekingz28
Mississippi
It seems as 2oohhound is correct. Maybe you should see if it will prime up.
Also, you could try a spray bottle- but I cant think of any that acetone wouldnt eat through.
mjoekingz28
Mississippi
So, what nuts and bolts would we find zinc on?
I dont want to ruin any kind of material thru use of Kroil.
