Inabox85
So i bought an inexpensive oiler. I wanted it for homemade penatrating fluid. Half ATF half acetone. But the mixture will not pump out. Is it a faulty oiler? Or is the fluid to runny? The oiler has a flexible line on it. The mixture does leak out of there a bit but it is as tight as it can get.
Should I try a new oiler?
Do you have any suggestions on the best dilivery system for homemade penatrating fluid?
