Broken Tap in aluminum
sparkness
Long Island, NY
I was power taping a part 1/4-20 tap, did not clear the chips as this is a deep hole, and a hand style tap - broke it in the part, any recomendations using alum and sulfuric acid for removal?
rancherbill
Foothills County, Alberta, Canada
shawhite
Must have been one dull or cheap tap. I’ve had moderate luck with the Walton like tools. Where you power taping with a hand drill/impact?
PCustoms
VT
I've broken them out with a punch before.
Not sure I'd want to mess with acid or alum?
neophyte
Pennsylvannia
Aluminum can vary from very soft, to hard and strong as hell, depending on the alloy, and whether the alloy was heat treated and hardened.
Also,
Aluminum is known for “galling” issues, which only get worse the more the tool is used once the molecular bonding happens.
This is one of the reasons titanium nitrate, and certain other coatings are recommended for tooling when working aluminum.
The coatings help prevent galling.
Kerosene is also the “cheap” recommended tool lubricant for working aluminum.
DIYNY
i'd try to stick needle nose pliers into gaps. if that doesn't work then comes out dremel with a carbide bit.
dutchgray
Dorset. England.
If the part can be put in a milling machine I will drill the tap out with a centre cutting carbide end mill, use a fairly well used one as it will probably not survive, the usually shatter when the last bit of the tap comes loose.
This is if the easy hand removal methods don't budge it.
Never tried any of the chemical tap dissolving methods.
F-22
1673298185999.pngSolid carbide left hand drill. This is my go to when all else fails.
Can this be used with a hand drill? Solid carbide drills are very expensive and I've only ever used one with a milling machine (but they come with normal spiral flutes, the straight one must be for very brittle materials?).
If I remember right, a ~10mm solid carbide drill bit costs 100€+, I doubt I'd ever strap it into a hand drill cause it's way more brittle than a HSS drill bit...
PCustoms
VT
No.
Carbide drills are too brittle and a hand drill too wobbly. You'll shatter the bit very quickly.
neophyte
Pennsylvannia
That type of drill bit is usually made for drilling hardened steel plate, such as that used for armoring vehicles.
Those bits should only be used in a drill press, and for drilling solidly placed materials.
Also, those bits tend to be expensive.
dnschmidt
Phoenix, AZ
I'd try heat first. Aluminum has a much higher thermal expansion coefficient than tool steel. Heat up the aluminum and see if that makes a difference.
sparkness
Long Island, NY
OK here is what I did, I put the aluminum drum in a glass jar of water, 10% battery acid, 4 oz of Alum(aluminum potassium sulfate), heated for 6 hours - completely dissolved the tap, the drum will get cleaned up back on the lathe.
sparkness
Long Island, NY
not so much an experiment, I did not want to remake the part and buy new material, I was too aggressive with the tap in deep cut - duh! my cost was $7.00 for the Alum, $6.00 for the glass jar, I had all other materials. the **** buildup on the aluminum is the iron from the dissolved tap.
