Brushless impact driver - what do you have and why?
willjogervais
Minnesota
Dealt brushless, I forget the #. Quick easy bit changes, although i leave a 3/8 impact driver in it 90% of the time. Ample power, enough to twist of many of said Milwaukee impact drivers. Lightweight and compact to get into small areas. It is probably my most used tool and I love it. That said, I have never used a different brand and can't compare
Locker537
Massachusetts
Milwaukee. I've had some M12 stuff for ~6 years and have been very happy with it, especially how long the batteries last. I ended up buying a bunch of M18 Fuel stuff and love it.
mike93lx
Richmond, VA
Dewalt 20v here, the three speed model. I like the size and specs, plus it was in stock at home depot when i had a project going.
Super Mech
Bronx,NY
Makita 18v lithium ion brushless impact driver. About five years old on original battery this tools owes me nothing. A true workhorse.
kctyphoon
Jersey/Staten Island
Milwaukee M18 fuel.. cause it's good, better than many, and I feel the Milwaukee system offers more of what I want - most of which feel better than other brands.
I have more brands and voltages too, but the m18 fuel is by far my favorite.. I have a dewalt 20v brushless, dewalt 12v, Milwaukee m12, and their m18 brushed model too. Some old Bosch 18v nicad that's haven't been touched in years...
mlum6969
ridgid..it was cheap ~110 for a set. looking to upgrade them to a milwaukee in the near future.
LawnBoy-5247
Kansas City
Milwaukee M12 fuel, I work on outdoor power equipment so I needed something small and compact that was fairly powerful.
Sent from my LGLS991 using Tapatalk
TNBurban
No brushless here. I have Bosch 4-5 years old 12V and 18V impact drivers but do not run them hard enough to warrant a switch to brushless. Maybe if I was putting food on the table with them I would feel differently.
Stuart96
Central ca
M12 fuel.. Plenty of power and a wide array of other m12 tools is a plus
yuanzichen
Atlanta, GA
I bought the Bosch for simply blind love of its name. It is the most accessible German brand in my area... only have light duty needs for it. No problem so far. Hesitant to get other Bosch tools though... actually hesitant to get any other power tools because kicking into a new battery system is pricey...
Sh40674
Iowa
just got the m18 fuel, been playing with the impact the last couple days... love it
KnurledNut
n/a
:+1:
Been using Makita LXT since it was first released in 2005 in a professional setting.
The impacts have been very reliable.
My current brushless model is probably my favorite, and has stood up to abuse without a glitch.
I dropped it off a roof some time ago and it fell 20 feet and hit concrete.
It survived.
Jazzman442
Tampa Bay area, FL
I do not understand the need for a brush less hand tools. Brush less motors have less torque on the lower end and are harder to control at slower speeds. I do not own any but I am looking at a Cordless ratchet.
xjfish
My Milwaukee 12v 3/8" Impact has been awesome. Used daily "professional use". Batteries seem to last longer than my snap-on 14.4 stuff.
Sh40674
Iowa
i should say i love it because of the speed and power. no issues in that department. i'd say the video you linked is realistic to what you can expect.. if you're looking i'd get one of the big 3, dewalt, makita or milwaukee... lowes and HD carry them, plenty of other stores. accessories, batteries, additional tools are always available, all 3 are good performers.
Ole Slewfoot
Freedom, CA
Fuel 1/4 because its small and light
Fuel 1/2 hi torque, because its big and heavy
Miwaukee because they are pretty good, and i already had batteries.
Somehow i ended up with a Ridgid drill, and if it wasn't orange, I honsetly might not be able to tell the difference, but they sure dont have the same resale.
mike93lx
Richmond, VA
Batteries last longer and tge tools are more compact.
exmaxima1
Midwest
Depends on the maker. Brushless motors typically have better low-speed regulation than brushed (they can microstep), and have the ability to have a locking torque though I've never seen one that does. Biggest reason to get brushless is enhanced battery life: besides more holes/screws per charge, you can only re-charge those expensive batteries a finite number of times.
BTW, I own M12 Fuel
Ilikeike
Northern Ca.
I moved away from Milwaukee cordless about 15-18 yrs ago, but I really like the new M18 fuel stuff. Unfortunately work is slowly upgrading the old DeWalt 18v to the new 20 volt tools over the last two years, so I went that way at home also. Just makes it easy when I need to borrow something.
Ign
Butte Peak ND
I've kinda wondered this, too, and this has sometimes been my experience, esp with drills. That said, I'm 99% Fuel so I don't find it that much of a problem. But my M28 brushed drill is a torque monster compared to even my 2704, and you CAN tell the powerband is different, like a diesel.
Really I think brushless is still in its infancy. Manufacturers will continue to find ways to make it better, like low end torque etc
Generally the brushless stuff is more compact which is nice but the M12 Fuel Hackzall is considerably larger than its brushed counterpart, so there are exceptions.
Git
S Cal
I have the Makita LXDT06. It has 3 impact speed settings:
0-1,300
0-2,800
0-3,400
The lower speed really works well when driving smaller/shorter screws and give you lots of control - especially noticeable when using Spax type screws and I am trying to sink the head flush with the surface
It also has a 'quick-shift' mode that has an electronic speed controller. It starts out at a higher speed for when your first trying to get a screw started and when it starts meeting resistance it will to a slower speed
If I was looking for a new one, I would strongly consider the Makita XST01M - it is brushless, 3 speeds and uses an 'oil impulse' drive mechanism which is supposed to greatly reduce the noise
https://www.amazon.com/dp/B00M9D5JIO/?tag=atomicindus08-20
dnschmidt
Phoenix, AZ
A comment on the Milwaukee SURGE. If all you're doing is driving screws it's the cat's ***. If you ever want to do any type of automotive work with it it's useless. A specialized tool for a specific application. For general use M18 FUEL.
Finky198
North East
Hilti. I bought into their 18v line 2010 when they ended their deal with HD. They recently redesigned the whole system but kept the battery platform the same!!! So I'm good for another 5-10 years. That's was a big plus the other is it hilti so it tough stuff. 6 years of constant use and They look, feel, and work like the day I got them.
They offer smaller lineup now as well I'm looking, but have yet to pull the trigger...
BikerDad
Utah
DeWalt 20v XR, 2nd generation. Only one speed range, does everything I want. I've been using DeWalt cordless tools since the mid 90s, happy with 'em. They fit my hand well, the balance is good.
IF I were buying new today with no investment in any platform, I'd go with one of the oil-impulse beasts which are much quieter. When DeWalt comes out with one, I'll almost certainly upgrade to it. I hate the noise of an impact driver.
Basically, any of the Big 4 (Makita, Milwaukee, DeWalt, Bosch) will do ya. Each has multiple offerings of Brushless impacts. Others that are fairly widely available in the US worth considering are Rigid, Hilti, Hitachi, Porter-Cable, Fein, Panasonic, Festool and Metabo. If you're a pro, then there's a good chance you can borrow a friend's for a day or two to get a sense of whether or not it fits your hand. Sometimes, no matter how good the specs, when you get your mitts on a tool it just doesn't work out for ya.
I will be upgrading my Bosch 12v Brushed impact to the brushless model sometime in the next year. Because, just because. :D
Local
Fallbrook,ca
20v DeWalt because it was free and has been solid for a few years. Only have one battery that has been reliable.
N
NitroGarage
Cleveland, OH
I think the brushless would do you just fine then. The kit promos make the Fuel much more reasonable (and possibly cheaper) than the brushless.
The m18 fuel kit with 5.0 battery and charger and case is 300 and the brushless with the same battery and charger is 170 if purchased separately.
bcradio
New Mexico
Or you can get an M18 Fuel hammerdrill, M18 Fuel impact driver, 5.0 batt, 2.0 batt, and hedge trimmer for $300.
That's what I just bought.
