Brushless impact driver - what do you have and why?
NoahG
Detroit, MI
I've had a M12 FUEL impact for 4 years now. It was the first impact I bought with more than one speed. I've beat it up pretty hard, gotten the housing hot to the touch driving deck screws, and its still going. Skeptical coworkers are always impressed after borrowing it.
I have the M18 FUEL is well, but honestly I think the M12 is designed and built better.
MacMcMacmac
canada
I have the 18V Bosch with the combo 1/4" hex and 1/2" square drive. Torques lug nuts tight enough that I can barely move them with a tire iron afterwards, so good enough for me! I also have a Mastercraft Maximum 1/4" hex drive that has held up very well for 10 years now. It was a rebadged Durofix/AC Delco. It impressed me enough to convince me to buy the 12V ratchet as well, which I am pleased with.
mailpup
Los Angeles
I have the DeWalt 20V Max XR brushless impact driver. I'm a DIYer and I have other compatible 20V Max tools to go with it.
pbon
I used to have Ridgid Nicad. I liked their lifetime warranty. Around 2007, I wanted some tools Ridgid did not have and found a CPO Milwaukee impact on sale and that started me down the Milwaukee road. I got 2 batteries and a charger with the tool and started buying bare tools, new or CPO or on sale. I now have about 20 Milwaukee tools -- 18V, Fuel, Brushless, M12, etc. I think they are pretty good and getting better and the selection is good for my needs and the cost is in my budget (versus Hilti or Snapon or IR or Matco).
Were I on a tighter budget, I would look at the Ryobi. I think Ryobi is a great value and has an excellent variety.
My needs are hobbyist, not professional. I have a lift and do all my own car work as well as some property maintenance, but am definitely not a full time pro beating on my tools every day all day.
The latest Milwaukee I just bought is a mid torque compact 18V Brushless 1/2 impact that does up to 450 lbs forward and 600 lbs reverse. It came out recently. I have bigger 1/2 impacts and a smaller 3/8. I got this from toolup during the current Milwaukee promotion. $189 for the bare tool, but if you buy one of a few other tools, you can get a free 9AH battery and charger and tool bag. I bought another 9AH battery as my other tool, so I got the 18V impact, two 9ah batteries, fast charger and bag for $358 shipped. The 9AH batteries are big but I already have a bunch of smaller batteries and want some long run time for my tripod light, vacuum, grinder and future SDS rotary.
The new 60/120 Dewalt stuff is worth a look if you are just starting and need big power. I am too far down the Milwaukee road to change and don't really need anything stronger right now. Battery tech is changing and whatever you get now won't be state of the art in 5 years.
Hlidskjalf
Toronto
For a brushless impact driver the Makita 18v DTD170 is a great choice.
The Makita 18 volt system is also a great investment for 2 reasons.
1. Their 36 volt system is just 2 18 volt batteries
2. There is no need to invest in 12 volt tools because their 18 volt line up has sub-compact tools that use 18 volt batteries, but are the size of 12 volt tools
Also Makita quality is great, I daily use mine on a professional level.
Rickster
SE PA
I bought the Bosch for simply blind love of its name. It is the most accessible German brand in my area... only have light duty needs for it. No problem so far. Hesitant to get other Bosch tools though... actually hesitant to get any other power tools because kicking into a new battery system is pricey...
I have the Bosch 12v lit Ion set - NOT brushless. They're great. I tossed the older small bats and replaced them with larger 4's I picked up off eBay. Just love them, compact and plenty of power. One thing I bought that turned out pretty useful is their mini Sawzall tool.
yuanzichen
Atlanta, GA
When did you purchase yours? Was it made in Malaysia? I had the same impact driver/wrench a while ago. Ended up returning it because it could not loosen my lug nuts at all.
johndeereman
WILL COUNTY IL
Milwaukee m18 and m12 both fuel and non-fuel tool's used daily / professionally. All of my stuff has held up extremely well on the job and in the shop.
Sh40674
Iowa
i had the opportunity to use the milwaukee surge this weekend. i have a fuel. surprisingly my fuel was just a touch faster. the surge was a little easier to control, and quieter. would i upgrade? no, the fuel is a beast. however due to the low, constant torque, it seemed the surge did better with phillips heads, where higher torque (like the fuel or most others) occasionally jumps off the head or strips it.
i'd say if you want something that's quiet because you can't stand the noise, the surge is a decent option. it also gives you a little better control.
if you just want a really good impact that wont quit, my vote is the fuel. it's a toss up, after trying the surge they're both excellent in their own ways, very impressed by both of them. i'd lean towards the fuel myself (i use most square and torx drive screws and noise doesn't bother me a bit)
Sh40674
Iowa
i should say don't let the low torque on the surge confuse you, it gives much lower torque but it's constant. the fuel was a little quicker, but the surge like i said put them in with a slight advantage of control and consistancy. literally a toss up, i love my fuel and liked my buddies surge.
