buffing wheel/compound chart
cheechi
Triad, NC
Is there an 'industry standard' type of chart for buffing compounds, or even a commonly referred to one, that is common to find as a wall poster? I saved parts of the packaging for several of my compounds over the years and don't use them very often, so they have stayed pretty nice but are starting to get worn. Rather than writing it all on a note that I will lose or get ruined, or have to go to a chart on a computer or tablet every time, I'd rather have something on the wall like a drill size chart. Or similar to a drill index chart the smaller ones, 'machinist handbook bookmark' sized that I could tape near a machine.
I'm sure I could find a chart that someone could blow up and print, and maybe someone has one already. I'm sure some supplier makes one similar to Norseman/Fastenal making the posters of the drill sizes. Having one from a trusted source means something I don't do often is harder to screw up.
second question, related. my wife complains about how much shedding the loose wheel does. I've wanted to get a few different of each wheels to keep specific wheels for specific compounds. For the most part I have been using the soft with white and the spiral with black, but I've got a pile of things I need to do with red.
so the actual question there; I assume some brands of wheels are better quality than others. Do the better quality wheels shed as much as cheap ones, or maybe not much/not at all? I don't know what brands I have, but a safe assumption would be either HF or Craftsman. Any suggestions of better and/or do I need better for occasional polishing blades and tools after they finish on the belt sander?
Edit: I should mention this question came about while working with a 6" bench buffer. However after reading the suggestion, I'd be interested in any automotive buffing answers too, even if that wasn't my initial intention.
bmw57isetta
Austin, Texas
You might want to check out the Autopia detailing forum at http://www.autopia.org/. These guys take it down to the minutia of products, techniques, equipment, etc. I may have gotten a matrix off of the www.autopia.com Web site. It's geared towards a comparison of foam pads to use with various compounds, cleaners, waxes and sealers.
Meguiars had a comparison chart last time I looked but that was a long time ago. The down side to that is they make so many products that all seem to do the same thing that I almost went cross-eyed trying to figure it out.
Let us know what you dig up when it's convenient.
pelletman
Worcester, People's Republic of Massachusetts
You're thinking the wrong kind of buffing!
I have done lots a buffing and have never seen a chart. You might want to ask in the Caswell Plating forums
toolenthusiast
3M does make large reference charts, maybe 24"x36". I don't know if you can get them besides through a paint jobber. This is what's on the 3M chart.
FYI the "wheel" is the pneumatic or electric tool that turns the "pads" which you swap out. If you don't want fuzzies everywhere, get a synthetic white pad instead of wool.
C
cheechi
Triad, NC
Are you referring to a terry or chamois type bonnet you put on the foam pad on a DA polisher? Or a bench grinder style buffer with stitched and loose wheels?
I'm thinking I may try out one of these based on the amazon reviews but I was hoping some here would have suggestions also. Searching through MSC & grainger sites is always such a pain.
C
cheechi
Triad, NC
for those interested this is as close as I have found so far to the real 'from the manufacturer' chart or poster I was looking for. http://dicoproducts.com/how-to.php
attached some from google images, was hoping to find one unified 'big ol chart' type of thing but so far the Dico is the closest to that, albeit limited it's pretty good.
