Finished building a water bucket dust filter system for the new media blaster cabinet this evening.
Materials included: bucket lid vacuum-home depot special, vacuum hose kit, 2 buckets, 1 lid, 2 rubber hose connectors(1 for blast cabinet to hose, 1 for water trap to vacuume) 2-male 1" PVC fittings, 2-female 1" PVC fittings, 2ft 1" PVC pipe, 1-90deg PVC, PVC glue, 2-o-rings for male connectors, hole saw(1-1/4 32mm).
Construction of the lid was pretty straight forward:
cut 2 1-1/4 holes in lid and installed male PVC fitting with o-ring to seal the connection. Cut a 2 spacer's out of a 1" PVC connector fitting. This takes up extra threads on the inside of lid and mates two fittings between lid. Cut 10-1/4" 1" PVC pipe so it will sit approx 1 inch above water in bottom of bucket. 90deg fitting attached to other side to help keep water from being sucked out of bucket.
Hardest part was gathering up specific vacuum hose fittings. Found a universal rubber hose fitter as well as rubber plumbing connectors which worked out perfectly(1-1/2 x 1-1/4 and 1-1/4 x 1-1/4).
Pictures attached.
Pictures attached.
