Bulb delay when turned on
vdotmatrix
Northern Virginia
panasonic bathroom fan FV-LP002 with light.
i replaced the bulbs. One is a panasonic bulb the other is a sylvania. The sylvania has a momentary delay and sorta clangs before it comes on.
Anyone have any ideas?
Bert_
NW Iowa
Kind of a "ping" noise?
They look like PL lamps, some have an integrated starter which would make that noise.
Bert_
NW Iowa
Ok, a ping…. These were 4/$12 on amazon. Get what i paid for them?
Assuming it's the right lamp for the fixture, it's not a problem. It's actually pretty normal to hear a "ping" when a preheat lamp fires up. Some are louder than others.
V
vdotmatrix
Northern Virginia
Ugggg. I have two similar fans in my home because rhey are quiet And **** a lot of cfms….. but i have not seen this in the bulbs i have replaced them with…
Lassen Forge
Different electronics in the bulb - The panasonic has a cap built in that holds the charge, when you flick the switch it fires. The Sylvania needs that initial start-up time to build the charge, heat the filaments and strike the "arc" in the bulb.
V
vdotmatrix
Northern Virginia
I wish I would have known that before buying these…. wish i coukd find an LED equivalent. It is annoying. Seems like older technology…
Lassen Forge
Yeah, I had a desk lamp with that same set up, and it is an expensive PITA about 1-2x a year when the bulb "soiled the sheets"...
I now have my dad's desk lamp when HE was a kid (think late '30's art deco), fitted with an LED bulb, and refuse to go back. If I had found an LED equivalent for my 4 tube, I would have snagged it, as it threw some serious light... just not for long.
alfredeneuman
Fullerton, CA
I just did a Google Search for "panasonic cfl light bulbs", and that was 2 of the results.
I dont see the panasonic brand. Does it specify doesnt not have the annoying delay and ping?
Lassen Forge already explained why the Panasonics are different from the Sylvanias.
Lamps Plus is another result......and there's always eBay
V
vdotmatrix
Northern Virginia
A.E.Newman....I was being facetious. sorta, but in all your "what, me worry wissssdom?", how can you tell by looking at the packaging whether or not it is going delay and ping, when turned on...I read what he said as to what is happening and why---but how does one shop for BUBS that don't do this? Thanks
V
vdotmatrix
Northern Virginia
anything I find is a replacement for the panasonic 2-pin, 13w, CFL bulb. Again, back to my question. how can you tell what circuitry you are buying?
cybrdyke
USA
The circuitry and performance information you want isn't available. There are many reasons for this which all boil down to...."it's not that important".
Now, it might be extremely important to you and that's fine. But CFL lamps have a myriad of different types and styles and manufacturers and they all behave slightly differently from each other.
You can look for something called a "quick strike (QS)" lamp. I know that Philips used to make them, but they were 4-pin and used an electronic ballast. They made these specifically for areas that are on occupancy sensors, like public lavatories.
A company like Panasonic probably doesn't actually make that lamp. They hire a contract manufacturer to make it for them. Quite often, they'll change contract manufacturers mid-stream. That means that you can buy the same lamp from Panasonic and it will be made by two different manufacturers, each with it's own behavior.
Added to this is the fact that you're using old style lamps and ballasts that are becoming less available. Most mainstream manufacturers have quit making them entirely, so the only available products are old stock, replacements made by small manufacturers, or LED replicants.
You're on a wild goose chase hunting down a dead technology. You can do trial and error if you want, or you can spend hundreds of hours on the internet trying to find out when, why, how a CFL lamps is made, and which one comes on instantly.
It might be easier to just replace it.
Good luck,
CD
V
vdotmatrix
Northern Virginia
Good luck,
CD
That is a great answer . Thank you.
V
vdotmatrix
Northern Virginia
Good luck,
CD
It is such a pain in the transistor. I bought these LEDs replacements for the similar panasonic model exhaust fan and the ^%$#@%$# would not work in it. Four pin lights, I give up...I am remodeling the upstairs after daughter leaves for college in the fall....maybe
Copymutt
Colorado
Just went thru a slow to light bath fan light, but it was incandescent. Thought maybe it was internally wired thru the heater coils or some other weird configuration. Turned out to be a flakey switch. Triple horizontal gang in a simplex box. Could not find a replacement. It was from an era that the switches were easy to disassemble and clean. Quick fix.
As of today everything is 110% in the wife’s bathroom. Had to chip roots in sewer, snake and flush roof vent from the roof and the sink, replace toilet innards, removed p.o.s. Corroded diverter as well as a self destructed pressure valve going to the shower. Flushed the H2O heater. Should have made a video of the dirt water and elm seed pods shooting out of the overflows.
Life’s lessons saved me as the light did not initially work after cleaning and reinstalling the switch. The bulb blew sometime during the process. Figured what are the chances, and trusted my meter and knowledge. On the back burner is a rain drop config for the roof vent.
A women w/o bathroom facilities is not to be ignored.
Bert_
NW Iowa
Despard switch. Not common anymore but you can get them.
Citation
Indy
If you don't mind some basic wiring perhaps you could remove the fluorescent assembly and mount something like this in the light
Basically install a traditional socket. You would need to limit the led wattage to no higher than the fluorescent lights since heat is often the power limit with an enclosed fixture (vs wire amperage limits).
