Hi Dennis et al,
I ran out of time and ordered the replacement PCB with the new current sensor daughter-board.
My semester ends in a couple of weeks... and I need to be prepared to complete the AWS certifications by then AND I need to prep and practice at home. My new job started a month ago, so I can't attend classes due to my new hours and need to teach myself at home so I can get full credit as well as AWS certs.
So... PCB kit came on Thursday, and I finished installing it on Friday night at about 2300.
New kit installed easily; my unit had some of the 'upgrades' that the kit was asking me to install. The .05 uF capacitors on the output as well as on the switch terminal to ground were already in place. I did install the fresh units as directed though.
New PCB looks drastically different though. That went in with a snap.
The current sensing daughter board in replacement for the original shunt was an interesting change. I wonder what the prompt for that was; looks like a drastically more sophisticated step forward in comparison to the sheet metal shunt that was in the unit on production day.
The unit does fire up now, and it does strike a nice arc with some 7018. I can see a difference with DCEP and DCEN. I can the see variance in current on the front pot in terms of bead width in my test plate, and the meter on the front of the unit seems to respond.
Observation to note is that when you fire up the unit, I see a VDC reading on the front panel meter that appears to hang between 55 and 62 VDC without any current flowing. I haven't seen any of the meters wiggle while welding; I can't watch the unit while welding at the same time.
In hindsight, I am very happy to have the machine working. I intend to play with it some more in the next couple of days, need to run it through some exercises to see that everything is working as intended.
Happy to get started!
Adam
