Calling all Walker Turner DP owners
ndfan6464
All over
So I finally got my hands on a Walker Turner DP at a reasonable price. I was hoping someone with the same press who has the original toggle switch box could send me some good pictures of it along with some measurements of it. I am going to make a reproduction of it for mine. As you can see mine has a awful looking switch.. this is my first Walker restoration so any helpful tips would be great. Also is this considered the 900 series? Thanks for any help you can give
N
ndfan6464
All over
That looks to be a 900 series drill press. Got one just like it for over 35 years and love it. Here is a link to the manual for it. Maybe you'll be able to see what the switchbox looks like.
http://www.vintagemachinery.org/pubs/detail.aspx?id=2244
Thanks for the information. I've printed off the manual. Looks like it'll come in handy. Only issue I've found so far with it is the motor humms and won't spin without help.
bmwrd0
Beaver Fever Oregon
I have one, not the original switch though. It has a GE motor on the back and a GE motor starter on the right side. I will try to put a put up a pic tomorrow.
N
ndfan6464
All over
Davefr
OR
Test the capacitor, centrifical switch and associated wiring. Don't let it hum for more then a few seconds or it can overheat the stator's windings.
bmwrd0
Beaver Fever Oregon
Motor wasn't a GE, but a Hoover. Cross slide is an Atlas. It had a cracked sheave, but a friend bored out another one for me, and now it is real accurate (drilled out a screw on a Snappy ratchet.)
Maui
Upstate NY
It measures about 3.375" long and about an inch wide. I've tried to attach a straight on photo but the website won't upload it for some reason.
Maui
N
ndfan6464
All over
Maui
Thank you for taking the time to measure it for me..
N
ndfan6464
All over
So I took the cover off the capacitor and found it still in the original box and wired. Is this standard practice? This is the first time I've ever worked with capacitors so forgive my ignorance. Also want to make sure I get the right one. This one reads 216-240 MFD 125 60 cycles. The replacement that I am looking at reads 216-259 MFD 110-125 VAC. It has the same manufacturer number. Both Vanguard B-216
I've tried posting pics but it won't let me. Keeps saying security token missing..
N
ndfan6464
All over
I was hoping someone is still following this. I could use some help on the best way to get the front pulley bearings out. Any help would be great.
bmwrd0
Beaver Fever Oregon
If I remember right, you tap the whole shive out from the bottom with a piece of wood. Then you can get to the bearings pretty easily.
N
ndfan6464
All over
Oh wow really!! Man that seems almost to easy..haha.. Thank you sir... I'll give that a shot
bubinga
LOL..........................I was going to ask you about the switch in the other thread. :dunno:
bubinga
HAHAH.. yeah I got a new switch. The original was horrible..
OK, I got it.....................
EDIT
Those D/P's don't come around here too often.
EDIT 2
I like the belt tension set up on these.
ndnchf
Fredericksburg, Virginia
When I restored mine, I upgraded it to a 3/4hp, 220v 3 phase motor driven by a 110v VFD. It plugs into a standard 110v outlet and give me full variable speed and plenty of power.
N
ndfan6464
All over
EDIT
EDIT 2
Is that yours!? Man it's beautiful! Jealous you have the slow speed set up. Iam still on the hunt for one that's not rediculous priced.
I got mine finished yesterday. I left it all original. The paint was still in great shape and wanted to keep this one untouched. Just cleaned it and repacked the bearings. Wiped it down with some T9 to keep it protected, modified a Delta stand for it and hooked up a foot pedal to it. Now it's home is next to my 40 CRAFTSMAN and ready to go to work.
jywilli69
Raytown, Missouri 64133
Since you like Walker Turner Drill Presses, I thought you might like this little fella since it also was made by Walker Turner. I borrowed a picture so you can see what mine looks like. Mine is torn down at the moment.
