Can anybody identify this spreader thingy ....
SHOOTIST357
GA 28x56 workshop
Any help on this one? I've had it awhile and have never had a use for it. Someone used it hard because there is a divot where the end of the bolt cut into the surface from pressure. No markings on it anywhere.IMG_0090.jpg
unslow1
Illinois
Kind of looks like it might be reversible and maybe fit a coil spring. Can you put a size reference in the pic? It does look a lot like a ball joint separator.
SHOOTIST357
GA 28x56 workshop
Ball joint separator?
No forked ends on it -- has cups like you would insert between a coil spring to spread them.
Not reversible, 9" long, and that is a 5/8" diameter bolt. Agree on coil spring but why....?
Debcrow
New Mexico
Proctology tool????
My first thought was possibly a split rim spreader, just a guess. How big is it?
vssjim
McLean Va.
It is a spring spreader for coil springs MOOG used to sell them so you could put in plastic spring spacers they sold. It was a way to get height back in to a chassis with out putting in new springs. I haven't seen the spacers in many years. The sprig spacers used to come in blister pack cards as an assortment for sellers. I found some NOS on Ebay to show what they looked like. The tools was not always needed but sometimes you had to have one.
SHOOTIST357
GA 28x56 workshop
I remember using the old twist in spacers--never used that type.
  • Like
Reactions: RTM
unslow1
Illinois
I remember that style. The modern replacement for those doesn't require a spreader. I think the rubber blocks are also still available.
SHOOTIST357
GA 28x56 workshop
Too bad I haven't come up with a good use for it yet -- as beefy as it is, I'm sure it would make a great little lift, or mini "jaws of life" to spread stuff.
I put a set of those in my '69 Impala. Even with that beast jacked way up, putting a pair into each rear spring was a real effort, would have loved to have that tool, and known what it was.
