darkside
I have a 5 gallo Coleman compressor. Can I leave it compressed all the time, never drain it only once in a while.
Ryan Wilke said:If you don't have any leaks, then you loose nothing by leaving it on. If it has leaks, then it'll run more often to maintain the air pressure, costing you electricity. The more it runs, the more air is compressed. The more air compressed, the more moisture may collect in the tank.
"I have a 5 gallon Coleman compressor. Can I leave it compressed all the time, never drain it only once in a while.
__________________
DARKSIDE "
The amount of moisture that 'falls out' of the compressed air is entirely dependent on the amount of moisture in the incoming air and the amount of air you use. If you're climate is where you have high humidity (more than 35% relative humidity [RH]), then you should drain your tank more frequently than if you live in a drier climate (less than 35%RH). If you're getting rusty water out of your drain, then the water is sitting in your system long enough to begin the rusting process of your tank...which will kill your tank eventually. That's why it was suggested earlier to drain your tank more often if you're getting rusty water.
This drain frequency will likely change with the weather and the amount of air used.
Bigger, commercial systems install moisture traps on the incoming air line just after the intake filters to catch some of the moisture in the air before it gets into your system (meaning more maintenance) and another trap again after the compressor. Some folks also install automated condensate blow-offs that "pop off" periodically via a clock timer which will blow the tank drain for a given duration (such as for 3-seconds) and frequency (say every 12hrs). Realize what you've got then is a timed "leak" that will cause your compressor to run more often....
For most home systems, most folks will be fine if they simply change their compressor oil annually, inspect their intake filter and drive belt annually and open their tank(s) drain enough to blow out any condensate collected there quarterly. If there is a piping system, shut off the supply valve at the tank, lower the piping system air pressure to, say 10psi, then purge/uncap each condensate drop leg in the system until each one clears out......
Good Luck!
RW![]()
HoosierBuddy said:I always leave my compressor off for two reasons:
1. It has a small leak and will kick on occasionally, wasting electricity.
2. My older brother's portable compressor once busted a hose and kicked on for a couple of days. By the time he found it, the compressor had walked across the floor (due to the vibrations) and up against his '96 Gran Sport Corvette...where it ate all the way through the paint and about half way through the fiberglass.
Mine is too big to walk off...but just the thought of it scares me.
Phil
..... not a good thing! The compressor would continue to supply "fanning combustion air" until the fire burns through the wiring and shorts out the compressor's power circuit.....which may be located on the other side of the building!
darkside said:I have a 5 gallo Coleman compressor. Can I leave it compressed all the time, never drain it only once in a while.
tommy said:I forgot to turn off my old small belt driven compressor once. It threw the serpintine type belt. The motor probably ran continuously for a week straight before I needed the air and realized something was wrong. (the compressor is upstairs for noise reduction.) With it upstairs, I was less than vigilant about draining the tank. The tank actually rusted through from the inside out... I think I'll go drain my tank!![]()
At my muffler shop we always closed the valve at the tank and turned off the compressor every night. the tank remained pressurized but nothing else. I do the same at my home shop. I don't see the big advantage of keeping it powered up.
.......I'm ready for one!
