Can I move these for more clearance?
narbie99
Need some more clearance for my lift. Do you guys think I could move these trusses further up to where I have the circles drawn? Looking to possible bring in an engineer to assess if this is possible.
Thanks!
mike93lx
Richmond, VA
You don't have trusses, they are rafter. That vertical member is odd. Guessing it was added at some point to deal with sagging on the tie.
Those horizontal beams are there to stop the walls from spreading. Moving them as high as you show probably won't work.
Where are you located? Please add it to your profile. Helps other advise so we know if you have to worry about snow, hurricanes, etc
Evilunclegrimace
Erie Pa
the last time I had a conversation with a code inspector I was told that the collar ties need to be in the bottom third of the rafter( height wise).
N
narbie99
Thank you. I will add. I am in Los Angeles. No snow,but do some some strong winds. Garage has 1 shared wall with the house. A few of those rafters are very loose, leading m to believe they aren’t doing much. Again I am no expert and its pure assumption.
tarmy
Nor Cal
You need some engineer to look at the idea you have. There are some stresses that are part of the system that need to be moved and accounted for. That ridge beam is going to be pushing down, and out, on that area...
johnnyradiant
Vancouver, BC
There appears to be already a couple missing from the two rafters on the right. A little odd. I wonder if the verticles were put there so the 'ties' could have been used for some storage by someone before that sorta knew better but figured he was gonna be light enough with the load?
N
narbie99
It could be, they are on loosely and each is held by no more than 2 nails on each side. Maybe thats all code requires? Not sure.
uscarry45
Yes I think it could be done but think the smaller "triangle" (you are shortening all three sides by moving up) will reduce strength I think you could add more to regain some of the strength lost so instead of 20" centers but them on 10" centers I am just taking wild guess looking at your picture. pay an engineer for a couple hours of time it will be well worth it
