Can I run my wire here
Motown 454
My stem walls are 30" above the floor ,I mounted my recepticle boxes 8" from the bottom of the box to the top of the 2x4 sill plate, which puts them at 39" to the bottom of the box. I did this so I can put shelves above the plugs. I'm going to drill the holes for the wire about half way from the box to the sill about 4" from each. Do I still put a staple between the hole and the box? I'm thinking yes. I'm running it below the box because of where they are on the side with windows. The side with the windows will have shelves between the windows. Under the windows will have nothing in front of them.
Thanks for all the help.
Here's a couple of pictures
Motown 454
Gooch Am I ok to run the wire below the box and do I need a staple if its only4" to the hole where the wire run through?
tfi racing
Cedar,BC
off topic but in my area its not code to install a receptical box under a window even if its GFCI protected.
What?We all have our own silly local interpretations,that's one of the dumbest yet,I would love to hear the misguided rationale behind that one.Nothing in the CEC about that,but as usual,Quebec,as a self imagined foreign entity,does have its own rules that are different from the rest of Canada.:beer:
Gooch
Petersberg, IA
you are fine to run the wire there, you should have a staple there for 100% compliance, but really, alot of romex jockey's wouldn't do it.
tdkkart
Eastern Iowa
If you watch much Holmes you'll know that he finds leaky windows quite often.
That said, we see outlets under windows all the time here, looking at one right now.
IANAE (I am not an electrician) I have been told that in a garage, the bottom of the box has to be 48" (or more) off the floor.
acer66
Western North Carolina
I think that is more of a preference thing, at least in the US.
People put them at those heights so they can lean 4x8 sheets against the wall and still use the receptacle.
oleguy
nope, you can take that box and nail it to the bottom plate if you want.
nope.18" min.garages are a classified aera as in fuel vapors.thats why gas water heaters need to be 18" off floor.
Gooch
Petersberg, IA
he said his frost walls are 30" already. but yes, if the bottom plate was on grade, they would have to be 18" off.
