Can I use this 100A breaker panel?
Nick_Wa
Northwestern Ontario, Canada
Just moved into a new place with a detached 24x24 with no power to it. Got some 6-3 teck cable to do a buried run to garage from house panel. Want to have 60 A service with 240 v in garage.
The old homeowner left this breaker panel, can it be used in the garage for what I want to do?
Thanks
The pic is a little blurry but it looks like the panel has a main disconnect with an interlock or lockout handle and branch circuit spaces. Its a Sq. D, do u happen to have a model #? You will probably have to buy a ground bar and isolate the neutral bus bar from the panel enclosure
Edit: The pic wouldnt load for me earlier so that why i said the above. Yup thats a 3-phase panel, so unless u have 3-phase, its a no go!
N
Nick_Wa
Thanks guys, that's the kind of info I needed. A 60 amp with a bunch of slots shouldn't be too expensive anyways. Figured I'd see if that one was good anyways.
Sent from a Galaxy Nexus in Canada.
tfi racing
Cedar,BC
Throw it on Craigslist,you should get more than enough to cover the cost of a new single phase box.
Check your favorite Big Box Store. The frequently have 100A load centers with a bunch of individual breakers for really GOOD prices.
where2
South FL
A Square-D QO 100A panel with 8 spaces (16 if you use double breakers) goes for $56 at HD (when you get them to match the Lowes price). :thumbup: Used one for my solar project.
