Can we completely replace our combo wrenches with ratcheting ones yet?
PretendMechanic
USA
Have they got that good enough yet?
Are they strong enough?
Slim/small enough on the ratcheting end?
I am redoing my mismatched sets of 6-24mm and 1/4-1" wrenches, and that got me thinking...
My portable hand box doesn't have space for anything excess, so basic combo 12pt wrenches always take precedent in there. Would love to have ratcheting wrenches in that box.
I don't think I've ever broken one but was always worried that I may, and probably had a lot more mechanical sympathy for that reason when using them vs a regular combo wrench. I do like to hammer on my regular combos...
The only full coverage no skip sets that I know of are from Tekton.
Thoughts?
*edit*
Forgot to mention I'm talking about working on passenger cars/trucks. Clearance and strength on the box end of the wrench.
Squankum
Southeast
No! Because I'm cheap! :D
I'm sure they're kewl, but I just haven't gotten into them yet. I did buy a nice set with few? no? skips from GearWrench -- flex box end combos. I just never use them. I could see myself someday finally getting around to shopping for the non-flex kind I'd really want and... my box is kind of full already.
(resumes buying hammers, sockets, pry bars...)
4xdog
Santa Fe, NM
I use my reversible ratcheting combination wrenches probably 90% of the time.
The times I don’t are for a size not in my Craftsman Professional/Industrial or FACOM gear, a clearance issue, or where a lot of force is going to be applied and I don’t want to risk the wrench.
f121
UK
The snap on ones ratchet wrenches are about the same thickness as ring spanners, so they’d give you similar access, I’ve not seen any others like it. The main place that ratchet wrench’s are less suitable is holding a bolt while impacting the nut, I imagine the impact would destroy the ratchet fairly quickly (maybe I should test this with some that have a warranty).
I used ratchet wrenches as my main set of years in the 00s, have tended towards regular combo spanners (preferably Facom 440) since and don’t use the ratchets that much. Probably as battery tools have got better and flex head ratchets became common, I need the access provided by ratchet wrenches less.
TobeyA
TX
I use ratcheting wrenches 99% of the time working on cars. Clearance is the main reason I dig out the traditional wrenches. And every so often, when I need to link 2 wrenches together to loosen a tight nut, I go to the traditional wrench.
zendriver
Indiana
I always bust loose/tighten fasteners with a regular wrench first/last.
Just seems dumb not to, but then mine are from HF, maybe not the strongest ratchet wrenches on the planet.
Maybe they are. :dunno: (or care)
ctandc72
VA
I've broken one ratcheting wrench in all the years I've been working on vehicles. It was cheap flex head larger metric - I was breaking loose a suspension bolt where the impact wouldn't fit and I was using another wrench hooked onto the open face side. It broke where it flexes - no surprise. It got the bolt loose thought. Still have that wrench, I modified it to work on another vehicle I was working on.
If I can't get the impact / 1/2" ratchet / breaker bar on it - and sometimes if I'm already under the vehicle and don't feel like getting back up, I normally just hook two combo wrenches together to break a large / tight bolt loose - but I've yet to break another ratcheting wrench.
They are tools. Meant to be used and yes, some will break. If I was doing it for a living, like I did briefly 30+ years ago, I'm sure my thought process might be different.
Fedwrench
Valley of the sun
Yes and no. It depends on what you're doing and what you're working on. I probably use ratcheting wrenches 90% of the time.
My favorite ratcheting wrench of all time has been out for years, and I feel it's the best ratcheting wrench out there offering you the strength of a fixed boxed end and the speed of a ratcheting boxed end in a single wrench in a standard length package.
Matco/Armstrong were the first to bring these to market a long time ago and mine are still going strong for the most part. My second favorite ratcheting wrench would be the first gen Dewalts. They had a Proto like anti slip open end, great feel and balance. Proto always has great ratcheting wrenches.
ecotec
At work, I use most ratcheting wrenches. I work out of a hand box. I can only fit so much in it, and I don’t want it to get too heavy. I have a regular 1/2” combination wrench for a job that the ratcheting wrenches do not work for. Anyways… I took the majority of my regular combination wrenches out of my work tools.
larry_g
oregon
If I may; The ratcheting wrenches will make a great ADDITION to your tool set but do not replace the regular combo wrenches. For the small tool box. You do not have to have every wrench you own in your box. When I head out for a job I load my carry box with what I will need and head out. The rest of the tools stay stored.
lg
YesIHaveAHammer
The ones I bought are spline drive. The fasteners always get stuck in them. I really dislike them.
So, I’m a firm no on this.
The style of wrench (ratcheting combo) is a separate matter from the type of end on it (spline, 6/12 point etc.)
Yarpo
Minnesota
Absolutely not.
The box end is just too large sometimes and in some applications.
Just ran into an issue yesterday that required a standard wrench. That said I'd prefer to always using ratcheting but not always doable.
CoThG
I naively purchased the Icon set of reversible ratcheting wrench set then they first came out. I gave that set to my daughter and replaced with the Snap-On Flank Drive Plus reversible ratcheting wrench set 6-19mm and I added the recently released 5.5mm size too.
Ditchdigger
Eugene, Oregon
Some years back I decided to test this hypothesis that the ratcheting box end wasn't up to the task of breaking loose stubborn bolts. I decided to use them any time they fit.
It's been like 5 years. I haven't broken one yet. Still waiting for them to be a problem. Do people still use a breaker bar with a socket before switching to a ratchet?
For reference, I work in automotive restoration. Taking apart things that probably haven't been apart in 70 years.
mikey03
So snap on is better than HF here?
Sumboodie
AK
I've had a set since the flex end ones became common about 25 years ago (no not the crappy sheet metal like 14 teeth Craftsman ones from the 90s)
Jure
Croatia
I have 8,10 and 13 ratcheting (wera joker),gave em away. I see no reason to own them.
cvairwerks
Within hearing distance of Texas Motor Speedway
The same way you use a regular non-ratcheting combination wrench?
Found way too many times that the open end angle on the combos doesn't always let you run the nut on or off, without having to resort to a different wrench. 30/60's work much better in the hydraulic world. Ratchet wrenches have their place and we have all sorts of variations in our tool boxes, but they are just about the least used wrenches at work.
AEAdam
SE PA
no
no
no
No skip sets of metric and imperial tools for cars and light trucks isn’t compatible with limited space in a hand box.
My advice: think more about what it is you want this box to do. Then refine what you add to the box to address those needs specifically.
Example: I carry a tool bag in my F150 that I’ve used more on other vehicles than I have the F150. Sometimes bicycles. I carry reversible ratchet wrenches 10-19, metric 3/8” sockets, lug sockets and often my Bosch impact gun. I have an old Bluepoint code reader, misc junky screwdrivers, a few pliers, zip ties, etc It’s come in handy. I think you don’t need much in a toolbag like this.
I will never ever use the 11mm ratchet wrench. I should just throw it in the trash. I think the F150 has no 12 or 14mm bolts or nuts.. But they have been useful helping other people/vehicles.
6 & 7mm ratchet wrenches could replace non ratchet wrenches in those sizes. Not sure I feel that way about 17mm+
jmarkwolf
Southeast Michigan
Thoughts?
*edit*
No.
Because sometimes you just want to hold the nut or the head. With a ratcheting box end you have a 50/50 chance of getting it wrong. Keep your combinations.
LXCam
My road box only has your typical combo’s. That way if I need to beat on it with a hammer of rock, it doesn’t break my heart.
drokihazan
Thoughts?
*edit*
I carry a bunch of tools in my truck, but the truth is that 99% of things I do on the trail or on the side of the road only require two mountain wrenches, an 8-10, a 13-15. Anything I can't do with those and a small socket set, I'm calling for a tow anyways and doing it at home. I don't even know why I carry so many tools in the truck. Your portable box doesn't need the perfect wrench for every situation, and if you're in a pickle bad enough to break a Mountain wrench you shouldn't be doing it in a parking lot.
ronkz650
Denver, CO
Snap on are the only ones that can compare to a standard box end. All the others are way too fat. The various manufacturers who offer ratcheting wrenches with the extended lip are decent, but not going to replace a box end wrench. All others with like a 2" wide head to drive a 1/4" bolt are more or less worthless.
rust in the eye
Chicagoland
Why do you consider that a bad decision? Too bulky? Weak?
mikey03
No. Why would you "replace" when you can just "add" to your tool box? There is nothing wrong with owning more than one wrench set. Is this even a serious question? lolol. :unsure:
:LOL:
If your carrying it then it gets heavy
