Don't expect 220 and 110 to ever go away. In some rural parts of the country, that is all the voltage they get at the end of the line.
Yeah, 220, 221 Whatever it takes!!![]()
Can we stop calling it "single phase" too?
Or am I alone in believing it's 2 phases?
There are set ups that are 120 phase to phase and 67 to ground. Not in residential. Then you got 208 3 phase, which gives you 120 single phase.
I used to do contracts with a utility, there is a pretty big + - then can give you for voltage.
actually it really is single phase. The phase does not refer to how many hot wires there are. There is a two phase system, but is mostly gone. I know there is still some in san francisco, and probably some old industrial areas. Two phase actually uses 4 wires. Look up Scott-T Transformer to see how two phase is connected to three phase.
Ok, single phase it is.
How about "3-way switches". I think they are 2-way switches; it either throws the power this way, or that way.
Anybody with me on that one?
Can we please stop using the terms 110 and 220? Residential voltage in the USA has been 120/240 longer than I've been alive. Do you guys still refer to costco as Price Club? (i was alive for that)
Do you actually know this?i dont know about where you are, but here there is a somewhat narrow range of delivered voltage. +/- 3 % or something like that.
sometimes used in recording studios, they call it 'balanced power'. Also isolated hospital operating room power I think. So no phase is grounded.
120/240 is single phase. Get over it. If you need to addle your brain, why is a three way switch a single pole and a 4 way a double pole. Hint - count the number of terminals on a 3 way. What did you get?
As far as phase goes, figure out whats meant by 720 deg, and 843 deg compared to reference. Then you will understand phase.
