Cantilever Two Handle Box
ephotrod
Texas
I'm looking for reviews on two handle cantilever boxes. Does anyone know if Snap On Makes the UT22K. Show your cantilever box and give me your opinions.
larry_g
oregon
Put your box number into the search engine here and it shows up in 6 other threads.
lg
no neat sig line
LB-1911
Northwestern Il.
Item: UT22K
Country Of Origin - CHN
https://store.snapon.com/Metal-Boxes-Box-Metal-Cantilever-5-Trays-22-x-8-x-9--P630842.aspx
Might give you an idea -
Hey guys, just cleaned out my portable toolbox, thought you might be interested.
This is the box I toss into the truck when I am working away from my shop. I might be in the plant fixing something, welding at another shop, working on my mom's car, whatever. It is mostly comprised of spares from my main box but there's a fairly complete set of basic tools in there. If I know in advance what I'm going to be doing, I'll kit up a bag with more specific tools.
What's in it? Well I spread it out on the surface plate and made a list.
Box is a Snap-On UT22K
Knipex mini bolt cutters
Pliers wrench
Channellock slip joint pliers
Channellock 420 tongue and groove pliers
Channellock 430 tongue and groove pliers
Channellock 360 mig pliers
Mac needle nose pliers
Klein diagonals
2x 10wr Peterson vise grips
Williams 1/4"-3/4" deep 3/8" drive impact sockets
Williams 10-19 MM deep 3/8" drive impact sockets
1/4"-7/8" shallow cman 3/8" drive chrome sockets
3/16" -9/6" cman 1/4" drive deep 6pt chrome sockets
T15, 20, 25 cman 1/4" drive torx sockets
3/16"- 9/16" cman 12 pt shallow chrome sockets
SO 1/8"-3/8" hex sockets, ******* homemade 1/2" hex socket
T30, 40, 45 50 cman sockets
SO F731 flex head ratchet
SO F936 standard ratchet
SO T72 ratchet
Unbranded 6" 3/8" extension
Cman 3" extension 3/8"
BP 1,3,4 inch extensions 1/4"
BP universal
BP spinner handle
Eklind standard and metric Allen folders
SO yellow instinct screwdriver set including minis
SO red short pick set
Mac 1/2"-3/8" adapter
9-17 MM metric cman RP wrenches
Vaco 8" adjustable
Cman 10" adjustable
Cman 3/8"-3/4 " RP wrenches
SK 7/8 superchrome wrench
SO 1-1/8 wrench
WF USA crescent 15" adjustable.
Stanley torpedo level
Ridgid 18 aluminum pipe wrench
2x jbauer 123 blocks
Mac compothane deadblow/brass hammer
Mac 16 oz ball peen
8" Nicholson half round smooth file with handle
Empire 7" speed square aluminum
Food grade anti-seize
Cman striking scraper
SO striking prybar set minus longest one black handle
Old as balls hacksaw
Astro pneumatic die grinders straight and 90 deg
various attachments for the die grinders
Stanley 25' and 12' tapes
M.F. Co Combination square
Dasco 5/8 cold chisel
Dasco center punch
Tekton 1/8 starter punch
Blue point 1-1/4 mirror
Cheap led flashlight
Stanley utility knife
Argon to air fitting purge adapter
Techsouth 1-1/2 cut block
Wire and buna-n gasket for 1-1/2 triclamp
General carbide scriber
Spare grinder nut
Anchor stainless wire brushes
Die grinder wrenches
Assorted zip ties
Kershaw taskmaster scissors
bonneyman
Desert SW
Dang that looks awfully close to a FACOM box I restored last year. I love mine - and yes, heavy when full.
48548
Phoenix
Wes J
Peoria, IL
I have a Kennedy 1022. I added grab handles at each end bolted through the main frame. That way I can carry it with two hands. It's not even full and it weighs over 80 lbs. Also, the hip roof design of the Kennedy lets you stand sockets up in the top tray.
The Kennedy is 10 inches wide instead of 8-3/4 or so that most other cantilever boxes are. Made in USA. About $130.
ZRX61
Solar Blight Valley, SoCal
They've cheaped out on the manufacturing process on both that SO & the Facom box. That lip around the edge of the trays used to by folded all the way over. Even cheap import boxes were that way. Now they have that stupid lip that does nothing except cut you.
I have a small cantilever like those, I folded the lips over with a door skinner.
John in OH
SE Ohio & Eastern Virginia
I've always liked cantilever tool boxes and the way they sort of "lay out" your tools rather than just pile them in a box like a typical hand-carry toolbox. Last fall I wanted to put together a "grab 'n go" set of tools so purchased a 20 in., five drawer, Excel TB122B-Red box for a little under $40 from Amazon. I'm pretty sure it's from China. Box measures 19.5" L x 7.9" D x 11.4" H, has an excellent powder coat finish, and I've been very pleased to date.
I don't have any actual pics, but these are stock views of the box:
Excel Cantilever Toolbox 20 in - a.jpg Excel Cantilever Toolbox 20 in - b.jpg Excel Cantilever Toolbox 20 in - c.jpg
My only complaint is the way the tray top edges are reinforced. The top 1/4 in. of the tray lips are bent over at 90 deg. rather than a full 180 deg. return bend. This causes the lips to partially obstruct access to the tray. I'm sure the 90 deg. bend makes for a stiffer tray, but, functionality of the box would be greatly improved if the lips were bent over a full 180 deg. You can sort of see the lips in the following stock pic:
