Car battery popping sound
Kaizen
New England
Have a few car batteries in the shelf and got a new charger. Did one perfect. Second one was on charger overnight as it’s a small charger. Noticed rice crispies snap crackle pop sounds from inside the sealed battery. Found some info talking about hydrogen but nothing conclusive.
Is this a sign of a short on one cell? I took it off charger and it continued the sound so I put it outside for safety. The case was not even warm.
LS6 Tommy
Northern NJ
A little bubbling on a lead acid battery during charging is "normal". "Crackling" is not "normal. I'd leave it off the charger until you can get that batter tested.
Tommy
K
Kaizen
New England
Thanks. I’ve never heard it before. Not worth burning down the garage over
nadogail
Coronado, CA
IMHO, that battery is probably out gassing. I believe that the gas, assuming the battery is a lead acid one, is flammable. I would put it into a well ventilated area and avoid any sparks or other ignition sources.
Had a battery blow up on me once when I hooked up a timing light. It was both dangerous and scared the **** out of me.
