Car service ramps
A
alan camby
South of Indianapolis, Indiana
They store vertically
Here is the latch. Notice how it floats with the uneven ground preventing a bind up. You can also see the difference in the KBS coating on the stand and the powdercoat on the ramp. The powdercoat is far better looking IMO.
Here is the latch unhooked. Just spin the nut and it swings off of the top of the bolt.
Used grade 10.9 bolts on this latch. The adjustable tire stop uses grade 8 bolts.
All these bolts are made by Lake Erie bolt here in Indiana.
bad_idea
Pasquotank, NC
Amazing idea came to me when I saw your picture of the ramps standing on end. Make a bracket to attach the two ramps 180 degrees from each other, call it 'nested'. Like this: l\ \l . Saves that much more floor space. If you don't want to disturb the paint anymore, you could tie them together and stick them in a corner.
A
alan camby
I have seen them stacked like this before:thumbup:
Knowing my luck, the one with the wedge pointing down would come undone and fall.
I might do this some time in the future though if I found a space they fit well like this.
Thanks
kald
Central Fl
Very nice build Alan!! I have a pile of 2" x 1/4" angle that I ahve been dying to use for something and this maybe it. Some casters on end may help moving ehn stacked.
JerryC
Memphis TN
I looked at that pic and thought that if you made one ramp wider than the other you could stack that wide one on top of the other.
Alan, they look awesome!
Can you put the stand on it's nose and then put the ramp on it? That would save you a little room.
A
alan camby
Thanks:thumbup:
Good luck if you try the build. It is a lot of work.
Just remember that 2"x2"x1/4" angle weights 3.19lbs per foot.
Took around 120 foot for mine. 120 foot times 3.19 is 383lbs.
A
alan camby
The one ramp wider then the other immediately made me think of the AMC Pacer.:lol_hitti
you know, drivers door a different length then the passengers.
Yes storage is a consideration that needs to be thought thru if you are interested in buying or making some. For now i am happy with the way they store. besides if i have them side by side like in the last picture, they make me think of a Christmas tree:D . Might put lights on next year.
Speaking of lights. One idea i had that i never followed thru on. Thought of putting a 110volt light on the bottom of one of the stands. Think of a automotive style fog light, something like that. I could just have a short 1' section of cord attached to the back of the light. Pull down my retractable cord from the ceiling and have a light that shines on the bottom of the car. The craziness in my brain never ends.
TAftw
I personally wouldn't use those with my truck. I tip the scales around 7000 lbs. and most of the weight is over the front axle. I collapsed a cheap-o jack last week when jacking up the REAR, and I just wouldn't feel safe working under those with that much weight over my head.
It's a great concept though, I'd like to build something similar with some thicker angle iron and make them a wider for stability.
mark52621
Nice design. I love the roller stop at the end of the ramp.
Add bar across from one ramp two the other. This will add stability and make that much safer.
I'm to lazy to run the numbers, but those ramps will hold anything you could drive without a cdl.
V-10 Killer
Midland, MI
Nice job on them. I see no need to safety nazi the hell out of it. Looks like they're already strong enough to drive a dumptruck over. If they were one piece, you could have mounted offset wheels at the tall end for moving them around.
A
alan camby
very nice job indeed sir!
Thanks, and welcome to the forum:cool:
What is your location/state?
This is a great thread. With your permission Im going to copy these ramps in the future.
just send me pictures:D
Please be carefull and build at your own risk.
I used my ramps and stands a few weeks ago and took a picture. Did not want to bump the thread for just my show off pictures.
BigSteve63
SW Missouri
Alan,
Just got through re-reading this thread - having used the ramps for some time, is there anything you would have done differently? Considering a set of ramps/stands for a winter project if things ever slow down at work.
Von Psycho
Holmes Hollow Ontario
I have a retaining wall made from 2'x2'x4' solid concrete blocks with catwalk from a factory on top forming 2 outriggers supported by the blocks and uprights made from 2x2 steel tubing, use your imagination as I **** at basic computer picture skills.
So 2' plus the 6" high catwalk puts the drive on surface at 2' 6" and lots of room to work underneath.
I first tested this out with 2"x4"s under each end and drove up onto to check the load/flex.
I've had this system for 10+ years and no negative issues.
Locker537
Massachusetts
Very cool project. :cool:
I have a kwik-lift at home and have been very happy with it so far. Like many others, I don't have the space for a two or four post in my current garage, but I really wanted something that made it simple and convenient to get my cars up in the air for most types of work.
https://kwik-lift.com/
I bought mine last summer.
bad_idea
Pasquotank, NC
Ran across this thread again looking for other things. How are the ramps/stands holding up? Any changes you would make to the design? I plan to build some similar stands soon enough.
