Carb cleaner vs. brake cleaner
chud
What's the difference between carb and brake cleaner? Any reason they can't be used interchangeably?
Elroy
kentucky
Ya
It's kind of like a carpenter usings a ballpeen to drive nails. It's does work but it is just wrong.
If you like, Elroy could go into more detail. That is if you really want to know.
Danglerb
SoCal
Either I would "guess" would be ok on metal parts, but on non metal, I would use stuff that says its OK for that type of material.
Carb cleaner isn't as aggressive I don't think as brake cleaner, so it might not work that well on brakes.
MXtras
On the Right Coast
The primary difference is that carb cleaner is NOT necessarily oil free, while brake cleaner has to be.
They both work for cleaning ****. I prefer brake cleaner for just about everything that mineral spirits can not be used to clean.
Scott
Deafautotech
Indianapolis, Indiana
i am use most of brake cleaner to clean oil leaking so i can check if it will coming leaking or not... carb cleaner is " clean and little lube" as my opinion which i dont try to use for clean the oil leaking or try to clean...
katit
St. Louis, MO
I dislike both because of smell. I use WD40 to clean and soften gunk and then after it's clean I clean it with brake clean to remove andy residue. This way I don't get high from that smell
jimmycrackcorn
Brooklyn, NY
like the post above carb cleaner leaves a residue, while brake cleaner for the most part does not.
I have to warn anyone who uses brake parts cleaner to clean throttle valves and around the intake, what comes out of the tail pipe when started is very toxic....
rsanter
visalia ca
brake cleaner is basically alcohol and will evaporate with no residue. you must use this in brake system work.
carb cleaner has some other stuff in that will leave a residue. for many thing they can be used interchangable but for some things you must use the specified solvent in order to break the crud you want to clean.
for most things I prefer brake cleaner
bob
Deafautotech
oh yeah!! it is awful! one tech did that and it got worse!! but long time tech always use carb and throttle body cleaner to do vacuum leaking to make engine run high if there is air leaking... FOrd have used a lot of plastic with rubber gaskets on intake maifolds...
Fedwrench
Valley of the sun
Not all cleaners are created equal. As has been mentioned earlier Carb cleaner has an oil base and if used on brake systems, can cause pad/shoe contamination and grabbing. Brake cleaner is an excellent all purpose cleaner but, you have to be familiar with the brand you're using. Some will damage plastics, most won't. There is a separate Electrical Contact Cleaner that dries immediately, leaves no residue, is safe on plastic but, is expensive. Brake cleaner is also harmful to your lungs and well being. Avoid breathing it whenever possible.
bmwpower
When using any product you should look at the ingredients to determine it's suitability.
Not all carb cleaners contain petroleum oils. The kind I use (SuperTech from WalMart) is nothing more than acetone, so no residue.
Acetone is bad for plastics and rubber, so don't use it on those parts. For drying wet parts or getting them residue free it work great.
jay50
Get GM top engine cleaner if you want the best for cleaning throttle bodies. You will never use anything else again. You can get it in spray can or bottle.
l_bilyk
Ontario, Canada
Most of products I use are CRC since they offer best value in terms of ounces/dollar. When we get cases of them we also get MSDS sheets. There is little difference between brake cleaner and throttle body cleaner. The specific gravity, volatility, etc. were almost the same. The throttle body stuff is purely a cocktail of organic solvents and is supposed to be safe for plastics. Brake cleaner contains some alcohol, and they say it is not safe for plastics but from my experience the CRC stuff is OK on plastic. The chlorinated stuff was quite different. Much more dense, and not OK for plastic. Smells different too.
wilbilt
NorCal
You can't even get good carb cleaner anymore. The stuff that would eat the skin off your hands worked best.
Uncle Buck
Kansas
I wonder when they stopped making the stuff in that formula? I have an old gallon of carb cleaner with the little basket that I bought and used around 1992-1994 and it did cause the top layer of skin on my hands to die and drop off! I still have that gallon of cleaner but I do not use it very often.
wilbilt
NorCal
You might think about transferring it to a new can (properly labeled, of course) every couple of years. I lost an unopened gallon when it ate through the bottom of the can!
T56 Impala
Roswell GA
CRC stuff rocks. IF.... you can ever get your hands on some XS-102, by all means, try it. It is wonderful stuff. Its made by CRC for ...... well.... a goverment agency. It is used in a few food processing plants for cleaning carbon deposits. Its clear, odorless (Really, no smell at all!) and will clean just about anything. Plastic, rubber, stainless, pot metal.... anything.
Stanger
Alton, IL
I also have a small can that is starting to leak. I wondered why, now I know. I already used the cleaner but have continued using the can and parts basket with lacquer thinner for cleaning.
Grant
kartracer55
Carb cleaner is more flammable? lol
I use carb cleaner for cleaning intake parts and diagnosing vacuum leaks. It also serves as a "ghetto" starting fluid when troubleshooting no starts
Brake Cleaner cuts oil and grease very well, and doesnt burn cuts quite as much, overall more pleasant.
3M makes an INSANE Carb/Throttle body cleaner though. It cuts gum and varnish like its nothing.
Uncle Buck
Kansas
Thank you for that advise, I noticed a bit of rust on the can but I had no idea it would be that aggressive! :wtf:
WVBrady
WV
I don't remember if this has been mentioned, but I read on another forum than throttle body cleaner is expressly formulated not to damage the special coating inside the throttle body. I always look to make sure that then can says "throttle body cleaner", rather than carburetor cleaner.
Brady
NITRO-BTU
MICHIGAN
Wd - 40
HELLO THERE, DOES WD-40 REALLY DISOLVE THE GUM AND VARNISH IN CARBS? IS IT BETTER THAN GUMOUT CARB SPRAY CLEANER FOR DISOLVING THE GUNK? FOR ANY OF YOU WHO HAVE USED THE WD-40 AND CAN TESTIFY, GOOD OR BAD, PLEASE FORWARD YOUR RESULTS. THANKS, JIM
katit
St. Louis, MO
No, I don't use WD40 for carbs or brakes. It doesn't work on carbs either.
I was referring more to cleaning engine leaks, oil pans, etc..
g9m3c
Tuscaloosa, AL
Brake cleaner all the way! Just be sure to use gloves because the stuff will irritate the heck out of your skin.
treasureseeker
Brake clean will melt certain plastics and one of them will swell some rubber seals like some O rings in a cars PS system. I think it is carburetor cleaner. When I worked for a Honda dealership (I did the used cars) I made the mistake of cleaning a cylinder head with brake clean. The exhaust from the car no matter how many times I changed the oil was toxic with a faint yellow smoke and my sense of smell was affected for months just for running it for a few minutes.
Seanbev24
Lynnwood, Wa
Both work well for diagnosing small cuts on my hands :bounce:
I use carb/tb cleaner for carbs/throttle bodies/intakes and for finding vacuum leaks.
I use brake cleaner for damn near everything else. If you took away my brake cleaner, I'd probably stare at the car for a while, throw a wrench, and head for the nearest happy hour :beer:
cglasgow
Depends on the brake cleaner. CRC Brakleen in the red can, for example, is a chlorinated solvent and does not burn (but releases toxic gases when exposed to flame). Brakleen in the green can, on the other hand, is non-chlorinated and is quite flammable. Smells like aerosol carb cleaner, in fact -- I expect that they are chemically quite similar.
So we've got at least four different substances being discussed in this thread: chlorinated brake cleaner, non-chlorinated brake cleaner, aerosol carb cleaner, and "dip" carb cleaner in the gallon can. All quite different from one another. Err.... five products -- forgot throttle body cleaner....
benny27
brake cleaner does not hurt if you have cuts but carb cleaner hurts.:mad:
Keep
Oshawa, Ontario
Surprised someone has not mentioned this already:
Do NOT use brake cleaner to clean parts prior to welding. The off gases can kill.
Davefr
OR
It's still avail. At least Berryman's B-9 Chem Dip.
Store the pail on a wooden pallet. A corrosive action will take place and eat the can if stored on a concrete floor.
blarf
Just to revive an old thread, the CRC red and green Brakleen are the same thing nowadays. At least in California. They're both labeled as being non-chlorinated, and their MSDS's looked strikingly similar to me (mostly a combo of alcohol with some nasty organic funk mixed in — chlorinated or not don't breathe it if you can help it). When I e-mailed CRC I got this response:
Dear Sir:
The product in both cans are the same. The two cans are offered to
meet our customer requirements.
Christine Richie
Technical Information Specialist
CRC Industries, Inc.
The 'power jet' new nozzles are nice, much easier to get the straw to fit into and get a nice controlled flow.
oldtools
Be very careful with brake cleaner. A lot of rubbers (like gasket and seal) are not compatible with brake cleaner. They will melt if expose to it. I accidentally spray some on my cm portable plastic box. The rubber portion just melted. I will get a pic post later. My friend clean his ac compressor and all the seals melted causing massive refrigerant leak. That is am expensive $600 lesson learned. DON'T EXPOSE RUBBER TO BRAKE CLEANER!!!
diggerrick
I love both.
I don't know about now, but in the '90's I saw a lot of Top Fuel teams cleaning their engine parts with CRC Brakleen. It used to have a warning not to let it come in contact with rubber parts, like brake piston seals. Maybe it still does- I haven't looked in years.
I've never had a problem welding after cleaning parts with brake cleaner because I let it evaporate and wipe it before I weld. You have problems when you spray parts that are clamped together and the stuff puddles in a pocket somewhere that it can't evaporate quickly. Do whatever you do at your own risk, but I wouldn't want to weld anything with puddles of brake cleaner hidden in a nook somewhere either.
And yes, the Berryman's carb cleaner is awesome, but even when I use nitrile gloves my wife complains about the smell and I know what I won't be doing that night.
cglasgow
Dear Sir:
Christine Richie
Interesting. I wonder which customers require that the product be in a green can and which customers require that it be in a red can, if that's the only difference? ;-) Not that I'm doubting it (haven't looked at either in a while), but it seems silly to have the same product under two different part numbers if the only difference is the color of the can....
mtkst19
blitzburgh pa
new crc/napa formula brake clean is ****. you get so use to the smell of brake clean you know when it is off. So napa sends me down the "new" napa/crc (red can) brake clean and i spray it-- smells like kerosene and leaves a residue.
compare the ingredients to old can-- same except for the addition of petroleum distillate. This is brake clean not lube...
so now napa's blue can house brand is on sale for 2.50 per can-- ill use it and stock up and grab 5 cases until it goes on sell again.
carb clean-- yeah i made the mistake of leaving a throttle body in the old can style over night. Came in the next morning and it was almost gone. carb cleaner ate the piss out of it.
