Caster recommendations for heavy steel bench
pelletman
Worcester, People's Republic of Massachusetts
I am looking at putting stem casters on a bench that has pretty heavy cast iron legs and a steel top, for mobility. I understand it won't be as stable as on the floor but I have other benches on the floor. I think it is about 48 x 24 but I will check that later tonight and if I had to guess maybe 3 to 400 pounds. The floor is pretty new smooth concrete. https://www.mcmaster.com/casters
Questions I have:
1. What is the best material for the wheels? I am thinking polyurethane
2. Should I put brakes on all 4 wheels, or just two on one one end or two on opposite corners?
I'd appreciate any advice as to material, size, etc. I have a 3/4 hole in the legs already.
Thanks in advance for your input!
tarmy
Nor Cal
ER Wagner or RWM 47 series...not flat spotting and locking models if needed.
I put the locking on mine...
bad_idea
Pasquotank, NC
All four wheels swivel or two straight only? Four swivel wheels is easier to maneuver in tight quarters. Two straight wheels on one end is easier to move longer distances but is more restricted in tight quarters. If you get two straight casters you can get away with brakes on just the swivel wheels. If you use four swivel wheels then you'll want all four to be locking.
Something with some weight to it I prefer all steel wheels. The table may only be 400 lbs, but what about all the stuff stored on the shelf and top? Not concerned about the load rating (4x300=1200lbs after all), concerned about the weight flat spotting any type of rubber or plastic.
exmaxima1
Midwest
I would look at hard rubber wheels. I put some "heavy-duty" PU wheels on a bench a few years ago and over the winter several of them split or delaminated from the hubs.
P
pelletman
Good point. I had that thought after I posted too. Thanks for the input!
PWC Repair
Arkansas
Don't limit yourself to stem casters just cause you have a 3/4" hole. You could very easily weld a 3/4 pipe to the back of a steel plate and use flange bolt style if you find a deal on 4.
lis2323
I agree. Plus be aware that 4 locking swivel stem casters would require STEM locks as opposed to wheel locks at they won’t roll but still wiggle around.
tarmy
Nor Cal
Thanks but I need stem!
Maybe I assumed too much...(stem castors as only solution)
Good luck getting a good stem castor, I suggested good castors assuming you could mill something to work if they fit your need...
My apologies...
lis2323
Here’s a few pics of 3” steel casters under my 4x8 foot welding table.
I used ALL swivel because it is important to me to be able to shift the table sideways or at an angle a few inches (or more) if necessary.
lilredex
Toronto
My bench uses old floor jack wheels and a jack under a front cross member to move it......very stable.
Dustball
Hudson, WI
Should I just weld a bolt to a plate? Is there a better idea?
Thanks for all the input! Much appreciated
Make your caster plates from thick steel and tap a center hole. Bolt the plates to your legs with the head of the bolts on top of the leg brackets going downwards into your plates.
metalmagpie
Seattle
Regarding swivel vs rigid: I prefer swivel casters where you can lock the wheel so it can't swivel. I call this swivel locking. On a flat floor if the table's heavy enough you may not need brakes at all. If you need to restrict the table from rolling you can just use short pieces of 2x4 as blocking.
metalmagpie
Dustball
Hudson, WI
I think you're underestimating the weight of your table. You'd also need to take into account the weight of anything you'd have on top of it and any dynamic forces such as hammering.
That's a very light duty caster you're showing.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I've used Caster City for several projects. I also have an all steel workbench that is quite heavy. CC carries casters of all sizes and types, from simple projects to industrial. They recommend Polyolefin wheels as the best material for resisting flat spots. My bench has plate casters, with one end fixed and the other end swivel. The swivel casters lock two ways, against turning, and against rolling.
ArkTinkerer
Where did you get these locking/leveling feet?
lis2323
Those wheel locks were purchased from Princess Auto on sale.
I modified them to make them height adjustable.
P
pelletman
Well, weighed the table today with a toolbox on top of it that may or may not stay on it. 1100#
P
pelletman
Well, it is nice to have a friend with a waterjet! I went with the casters I had. The top of the bench is now at 40" which is a bit tall but I will live with it and I am pretty happy with the results I think. Haven't really used it but that will come soon
u2slow
BC
One caution I have with poly casters is when loaded heavy, they distort and have considerable rolling/swivel resistance.
The 4" iron ones I put on my engine hoist are great (providing you sweep the floor well). But the 6" poly coated ones on my 'axle cart' (usually has 3 or 4 on it) make it hard to push around.
John Timmins
Flagler Beach, FL
Surplus Unlimited catalog has a LOT of wheels to choose from.
Also look at the Kreg Tools site. I bought a workbench frame from them and then bought their wheels for $60 I think. It's been awhile. They swivel, and lock
Slednut
Washington state
My SIL built this table and I don't know where he got them but the casters are really nice. The wheel and swivel locks and it has a cast iron wheel with a thin polyurethane tire.
velocipede
Yorktown, Virginia
Poly wheels will disintegrate after 10-15 years and you will have to replace them. Every tool/bench/storage cabinet in my shop is on wheels. I've had to replace them all. Typical damage:
