But then he wouldn’t have been able to make a cool videoThis same video has been seen on here before. Not too long ago IIRC. You can see clearly in the video where the drain bung has been welded on and not done skillfully. I think if he had taken it out of service when it (probably) started leaking previously he wouldn't have had the catastrophic failure.
I think the point is that when it needed a repair that should have been taken as a clue that it was time for a replacement. Yeah the repair wasn't the failure point but if there's one spot that needs a repair their are likely others.
It looks to me like it was rusted through along the weld to me as well. Who knows, maybe there was a repair there also that got a bit of red paint and it isn't apparent.I think the point is that when it needed a repair that should have been taken as a clue that it was time for a replacement. Yeah the repair wasn't the failure point but if there's one spot that needs a repair their are likely others.
Looking at the screen capture above it looks to me like it's rusted all the way through at the failure point and was likely leaking. Obviously, that's pure speculation on my part but that's what it looks like to me.
The take home message is still the same. Compressed gassed can be dangerous. Drain the water regularly and don't use old, suspect, pressure vessels.
Ok, I'm going to switch to cordless in my shop.As much as cordless tools have overtaken the use of air tools, I don't know if an auto repair shop can ever completely get rid of air? I need it to blow out dirty/plugged hoses/passages, blow dirty filters, air to fill tires, pressurize things to check for leaks, etc, etc. Far too many uses for air in a shop to completely get rid of the air compressor.Ok, I'm going to switch to cordless in my shop.
I rarely use my compressor these days.... but when I do, I always cringe the entire time it's running after seeing similar threads/stories over the years on the internet of blown compressor tanks. In fact, I used my compressor the other day to run my little air body saw for about 15 minutes and the thought of an exploding tank was on my mind the entire time the compressor was running.
JMHO, but in the subject tank in the video more likely there was some part of the pressure shutoff and/or overpressure relief valve which failed and drastically overpressurized a junk tank.
But the fact that it needed repairing should have been all the indication needed that it was past its useful lifespan. I know this is Garage Journal and we like to fix things instead of replacing them, but some things shouldn't be fixed. Like pressure vessels.
But the fact that it needed repairing should have been all the indication that it was past its useful lifespan. I know this is Garage Journal and we like to fix things instead of replacing them, but some things shouldn't be fixed. Like pressure vessels.
I knew the pilot on that one.
Happened to me. Forgot it on, pressure switch stuck the next time it kicked on and the compressor was pumping while blowing air out of the pressure relieve poppet for a good 24 hours before I found out. I replaced the pressure switch and installed a mag starter with a indicator light to remind me it is on.Agreed - test your pressure relief valves - at least annually.
Wouldn't be the first time a cheap pressure switch stuck, and kept right on pumping.... until something else gives up.
They won’t rust.Ya know...we wouldn't have these problems if we made compressor tanks out of PVC.
Or just replace the safety valve after 5 or 10 yrs or if the tank is new to you. They are not much money.Agreed - test your pressure relief valves - at least annually.
By test, i mean prove it yourself. Should even do that with a brand new one.Or just replace the safety valve after 5 or 10 yrs or if the tank is new to you. They are not much money.
Rust on the inside of a tank from moisture buildup is fairly normal unfortunately, especially if you do not drain it regularly. It's best to check the tank and see what the test date is on it and go from there to figure out it's service life.Right before winter there was a damp spot under my twin tank compressor and I saw it was spitting out of a rust spot. I haven't used it since.
I mentioned that more as a safety point. The tank leaks it's not getting used any more.Rust on the inside of a tank from moisture buildup is fairly normal unfortunately, especially if you do not drain it regularly. It's best to check the tank and see what the test date is on it and go from there to figure out it's service life.
