And worse... if tanks don't rot out, it's harder to sell another one.Compressor tanks would last longer if they were fitted with Automatic Drain Valves; that probably will never happen for the majority of the home shop compressors sold becuse it would raise the cost of production and purchase price.
Commercial or industrial duty compressors do not come with auto drains either so it is not just the residential market.Compressor tanks would last longer if they were fitted with Automatic Drain Valves; that probably will never happen for the majority of the home shop compressors sold becuse it would raise the cost of production and purchase price.
I think Champion includes them on at least some models.Commercial or industrial duty compressors do not come with auto drains either so it is not just the residential market.
But as a manufacturer you are not going to add a $100 auto tank drain to all your compressors and price yourself out of the market.
During the failure, the crack propogated to the seam. But where the crack started, that's the real question.
I agree, it's not clear the failure started at the seam vs that was the weak point/the weld bead forced the failure to follow vs cross the seam. In looking at the video there was another area where I would have guess the failure to have started but I personally can't make even a 50/50 claim absent looking at the thing. It doesn't appear that the seam is on the bottom where rust thinning is most likely. Rather the seam is about 1" vertically up from the bottom.During the failure, the crack propogated to the seam. But where the crack started, that's the real question.
Are you going to cut the tank open to see what inside looks like?Looks like it's time to buy a new air compressor, after seeing that video, and then reading all your comments. My compressor is very much like the one that exploded. It's a Campbell-Hausfeld 20 gallon 'hot dog' type I purchased new around 1995.... so it's at least 26 years old.
I have drained water from the tank very infrequently. Just did it yesterday. Got around 2-3 ounces out. first came out rusty. then cleared up at the end. I can't trust this thing anymore. I don't use a compressor all that much. I'll be getting a small pancake or small twin-tank to replace it.
Also decided that I'm NOT going to sell it. It will be dismantled. I might try to sell the motor and pump, W/O the tank.
as long as you got it dismantled, drop a bore scope inside and see what's there. Might change your mind.Also decided that I'm NOT going to sell it. It will be dismantled. I might try to sell the motor and pump, W/O the tank.
Have you been welding up holes in the bottom of your tank? If no then don't worry. I had a similar CH vertical tank compressor. I was kind of pissed when it sprang a leak. At that point I scraped the tank. Luckily I was able to find a similar tank so I transferred the pump and motor over to the other tank.Looks like it's time to buy a new air compressor, after seeing that video, and then reading all your comments. My compressor is very much like the one that exploded. It's a Campbell-Hausfeld 20 gallon 'hot dog' type I purchased new around 1995.... so it's at least 26 years old.
This have been posted here before, and probably before that as well..... looks like the same compressor?be careful
I'm not a welder.....Have you been welding up holes in the bottom of your tank? If no then don't worry. I had a similar CH vertical tank compressor. I was kind of pissed when it sprang a leak. At that point I scraped the tank. Luckily I was able to find a similar tank so I transferred the pump and motor over to the other tank.
If you do insist on scraping the thing, sell of the motor and pump. That might get you enough money to buy a smaller replacement compressor. I also suggest getting one of the quiet compressors. They are so much nicer to be around vs the more traditional pumps.
