Ceg single phase 230v motor need help
gmoscajl969
Need help on how to connect this motor to my 240v plug need to know where the wires from my 240will go on the motor also can someone tell me how to read the information plate
rockwithjason
Las Vegas
The pics arent clear enough for me to read but that is iec nomenclature. Do a google search for iec motor reconnection diagrams and you will find what you need
mm08822
It is a Permanent Split Capacitor (PSC) Motor.
It has a squirrel cage rotor and a stator. The stator has two windings – main and auxiliary winding. It has a capacitor hard-wired in series with the “start” winding. There is no centrifugal switch.
5 Hp = 3.7 KW
1690 RPM (4 pole)
230VAC, 60HZ = Rated voltage (95 – 105% rated voltage = rated output)
19.6A = Full Load Amps at rated output
Class F insulation = Insulation Temp Rise = 100C
Ser.S = 1 (Duty Cycle – S1 means continuous duty and Service Factor is only 1.0)
IP 55 ~ Dust tight, Protected from water jets
Power factor ~ 0.9
Capacitor = 70 micro Farad, Voltage rating = 460 VAC
Motor size (frame size) = 112
Anlauf = “Start” winding (determines direction of rotation)
Betrieb = Run winding
No mention of overload protection. Should install something.
