ceiling fan blades (colors?)
bobbyb
new kent, va.
I'm in the process of hanging 2 ceiling fans in the garage. The fans are all solid white and don't look manly enough to hang in the garage.:cool: So I was wondering about painting the blades and the only thing I can come up with is paint 2 black and leave 2 white, but that is kinda bland. Ya'll got any ideas?
Charles (in GA)
50 mi south of Atlanta
Not sure what the issue is, its a garage, unless you are decorating it like the inside of your house.
Charles
srmofo
SW ohio
I like red. Plus it'll help you see them when on, so you dont stick things into them.....unless you have a barn sized shop like him^.....can you feel my envy?....they might look pink though if everything around them is white.
Full Size 66
Wa.
In my last real garage I got a fan for free from my buddy. It was white as well I carefully removed the blades and painted them semigloss black and put hot rod, tool, and dirtbike related stickers on the blades. No problems with manlyness again. :thumbup:
bobbyb
new kent, va.
Thanks Full size 66, this is the stuff I was looking for.:thumbup:
bchee
Texas
I just painted some valspar aluminum. It has a speckled metallic finish.
Vettman
Ca. Sierras
Might look good sprayed with cast iron enamel. It'll look just like grey cast iron, and won't show much dust/dirt etc.
The Hot Rod Grille
Winfield, WV
My fans are white. I guess it's not very "manly", but my fans aren't the focal point in my garage, so I don't mind that they blend-in with the white ceiling as long as they circulate the air!
Jim
Falcon67
Merkel, TX
I like the plane prop idea. In my experience with ceiling fans, white shows dirt real well. Along with black, brown, red, green, blue, orange,....
Stuart in MN
Minneapolis
I don't know that I'd want a bunch of different colors whirling around on a fan blade, it would be distracting. There's a reason they're normally white or some other neutral color, so they visually fade away in the background.
maxwedge
Bloomington IL
I picked up a used white ceiling fan at a garage sale for $2...and then painted it with chrome spray paint, which from a distance looks more like aluminum. I figured if it sucked I would just throw it away and be out $2, but it turned out okay. I'll try to get a pic later.
I also think it would be kinda cool to get the radiator fan off a large diesel and attach it to a regular ceiling fan motor for the garage fan...they scrap them out all the time where I work.
Gary S
Bismarck, ND
What kind of manly do you want? For real manly, white is just fine. If you want girly-man, try pink or peach.
jdub63
Azle, Texas
x3 the prop theme, maybe a swirl on the nose cone....
from the mighty Herk...
to make it truly prop like....make it look like it's leaking :)
Brad1234
Since they are already white how about a black & white checkerboard pattern? Your half way there.
