Ceiling Insulation in a Kit Garage
jacric2005
Lane County, Oregon
My garage is a kit. 28 wide X 34 deep. The joists are 24" apart and clear span - no support wall in the middle. There is lots of stuff attached to the joists - like a bunch of flourescent lights and garage door opener hangers.
I am thinking of 1/2" plywood or OSB on top of the joists and tacked on, with some blown-in insulation or foam board on top of the plywood. It's not really engineered to store any weight up there anyway. This way I won't have to take everything down to put the plywood on the bottom of the joists.
I'm trying to be frugal, but I wonder if I'll regret it will look a little funky. It's a workspace, not wanting it to look like a living space.
I'd appreciate your ideas/opinions. Thank you.
Marctrees
TX/LA border - Toledo Bend
There is poly w synthetic scrim reinforcement that one would staple... designed to support blown insul.. works for 24" centers... as one maybe possible option.
Marc
J
jacric2005
Lane County, Oregon
I hadn't thought of fitting around the web pieces - :(. Also I noticed no electrical boxes for the fluorescent lights. Also what I think was supposed to be an engine lift (put a pipe for support at the end that is strapped to the joists and use a chain and come-along??) that needs to come out. And, it has outlets on top of joists for opener cords.
I'm thinking best thing is to take everything down and do it right for sheetrock. I can learn how to put in electrical boxes for one thing. Picture included of some of my work on the walls - fiberglass and painted OSB.
Marctrees
Yeah ...................
That wiring really needs to be cleaned up....
Obviously totally done by the opposite of a Pro.
Visually seeing how the wire was run tells us there are many other Code - SAFETY - infringements.
Honestly, overall best and easiest to rip out, and start from scratch... including replacing the panel... it is a small expense in itself.
Sorry to say, but yeah.
Marc
J
jacric2005
Lane County, Oregon
Marc
Yeah that’s what I was afraid of. Good time to do, maybe can add some stuff while at it.
