Ceiling insulation
Breakineven
Minnesota
Any ideas on the best way to tackle this other than paying the big bucks to have someone spray it? Thanks!
nadogail
Coronado, CA
Put up drywall and blow in cellulose. You can make your own cellulose insulation from old newspapers and Boric Acid powder by feeding those ingredient into a Hammer Mill.
billconner
Thousand Islands NYS
At least Fabral has span table data to 8'. These looked to be 6'? Check on truss design - should be on drawings - and see how much cellulose it can hold.
loganb
Omaha, NE
Verify weight limit for the trusses but first options I think of are metal liner panel with blown in above or look up insulation options for pole buildings as they often have wider bats that work better on larger spans like you have. You can then cover with liner panel or leave uncovered as long as the insulation is properly attached and not a fire hazard.
HoosierMark
Southeast IN
My builder installed metal ceiling panels and then blew the insulation in. I had him make two 3 by 5 access holes near each end (just in case). He used batts to insulate these areas. Trusses were 5 foot apart and 36 foot long.
racecougar
Missouri
When I did my building, I had the trusses constructed for the anticipated ceiling load. I added the ceiling joists between the trusses, installed vapor barrier, sheeted it with metal, and blew in fiberglass. I have been very happy with the results.
49753674_10100369123232093_2504584503347904512_o.jpg57186114_10100395883733833_5545750747137703936_o.jpg
